sonic
posted on 10/4/16 at 07:19 PM |
How to replace the brake fluid on my Indy
Hello guy's
The time has come to replace the brake fluid on my MK Indy, whats the best / quickest/ easiest way of doing it ?
Mick
Matt21
posted on 10/4/16 at 07:39 PM |
Buy an 'easybleed' kit
you just fill a bottle with fluid, connect it to the top of your reservoir and plug it onto one of your tyres.
the pressure from the tyre pressurizes the bottle forcing the fluid out into your reservoir and as you crack open each bleed nipple of the calipers,
it goes out into the brake lines.
start with the furthest caliper from the reservoir and work your way through them to the closest one. then your done.
a length of pipe is handy to go from the bleed nipple to a tub to collect the old fluid, stops you making a mess everywhere!
and also a syringe to suck excess fluid from the reservoir
and remember that brake fluid is a brilliant paint stripper! so be careful what you get it on and give it all a good clean when your done
Slimy38
posted on 10/4/16 at 08:27 PM |
What he said, with two tips;
1. Don't drain the old fluid first. Just keep on bleeding with fresh fluid until the stuff coming out changes colour (as seen through the length
of pipe). It's infinitely more difficult to bleed an empty system, despite it seeming quite logical to remove the old before the new.
2. Ignore the eezibleed pressure requirements, they're too high and chances are you'll have difficulty keeping a seal on the cap. If you
do hear air (or fluid) escaping, drop the pressure and try again.
hizzi
posted on 10/4/16 at 08:33 PM |
easiest way,is to pay someone to do it !
posted on 10/4/16 at 09:33 PM |
First tool you need is a Turkey baster to get as much fluid out of the fluid resevoir as possible before you refill it.
Only then bleed the system through, if you want to do a really thorough job push the caliper pistons back to reduce the ammount of fluid in the
calipers.
Then refill and bleed an Eezibleed will make bleeding easier but use the mininimum air pressure that gives reasonable fluid flow.
posted on 11/4/16 at 08:24 AM |
Never changed the brake fluid on my Indy, but IIRC it was easy enough to fill from empty. The only air I got trapped was in the 3 way pipe union at
the rear, which had a hydraulic pressure switch for the brake lights. Cracking that open got rid of the air, but did spill a little brake fluid.
