Chris_Xtreme
| posted on 20/5/16 at 08:56 AM |
what type of bush is this?
There was some play in the rear lower wishbone bush on the xtreme.
I eneded up having to cut the bolt on both sides as it had rusted onto the inner sleeve.
This is what slid out - I hope cracked before I was hitting it with a hammer to explain the play, else I don't know how it was giving any
movement.
Any way, in case I don't get a reply from Mark at Quantum, anyone know what type of bush this is ?
photo link
thanks
[Edited on 20/5/16 by Chris_Xtreme]
| posted on 20/5/16 at 09:26 AM |
Have you (or anyone else) got a build manual?
Might say in there what bush to use during the build.
Chris_Xtreme
| posted on 20/5/16 at 09:38 AM |
unlucky for me, I have already tried that
the manual just lists Quantum own part numbers.
cheers
| posted on 20/5/16 at 09:58 AM |
Shame - I thought it might define the bush for you.
My other technique is to call on a local friendly motor factor and ask - he can usually identify the part or suggest an alternative part. Probably
worth taking your wishbone in as well so you can check the ID of the tube the bush has to go in.
adithorp
| posted on 20/5/16 at 11:04 AM |
Dont recognise it. Looks from that like the outer is in 3 sections, which would be strange. Do you have another view/angle?
http://jpsc.org.uk/forum/
Chris_Xtreme
| posted on 20/5/16 at 11:14 AM |
short video of it
https://goo.gl/photos/mBsjn9DKLg2FK2bq6
hizzi
| posted on 20/5/16 at 02:30 PM |
measure the tube and the bush size and contact duraflex on there website or ebay, they will have them or make for you. looks like the standard seven
type wishbone bush but with extra bit in the middle
Chris_Xtreme
| posted on 20/5/16 at 02:55 PM |
cool - thanks, I've sent them a message.
hizzi
| posted on 20/5/16 at 03:05 PM |
just looked on ebay might have been floflex i used but they seem to do exactly the same stuff
Chris_Xtreme
| posted on 20/5/16 at 03:15 PM |
I'm trying them too !
cheers
Dingz
| posted on 20/5/16 at 08:19 PM |
Looks like 2 top hats with a spacer bush.
went on and on.
Chris_Xtreme
| posted on 23/5/16 at 12:01 PM |
order placed with http://www.duraflexpubushes.com/
lets see how they do! (or how I have done with my measuring!)
