sam919
| posted on 12/6/16 at 08:10 AM |
High Angle Steering UJ
Has anyone come across a steep steering angle between the rack and column, therefore requiring a UJ with more than 30 dog of angle. My current
situation has two at around 40 degrees but they're binding, I have room for a double but it then all starts looking a bit un-engineered.
I can move the column back to decrease the angle, put a double in or find a higher angle UJ/ helicopter joint, I just haven't found one yet?
Any ideas
mark chandler
| posted on 12/6/16 at 08:29 AM |
Drop another UJ in the middle and support the shaft with a rose joint.
rdodger
| posted on 12/6/16 at 09:48 AM |
http://www.woodwardsteering.com/PDF/3.%20Steering%20Universal%20Joints%20and%20Splined%20Couplers-1.pdf
Woodward do some nicely engineered solutions. Inc doubles.
sam919
| posted on 14/6/16 at 07:35 PM |
Thanks for the replies. I welded two together and I'm still not getting the angles without binding, that's using three. I've a MS
helicopter joint which seems to be happier at its 30 degree limit so I'll get another and with the 30 deg im achieving by rotating the rack I
should get there.
The internals of the joint look similar to the Woodward units, finer engineering
