LBMEFM
| posted on 5/7/16 at 07:18 PM |
Tracking
What do most of you set your steering tracking too on MK Indies?
r1_pete
| posted on 5/7/16 at 08:31 PM |
Not a kit but Ive just rebuilt the front end on my 944
I used a laser level, set parallel to the back rim, then set a very slight toe in using a rule, the laser strikes a nice thin line on the rule, Inwas
able to get the toe 1mm in per side.
Ben_Copeland
| posted on 6/7/16 at 05:53 AM |
There's a chap in Dover that did mine if you need someone to set it up properly. Races escorts
Rough settings should be around :
neg 1 degree rear camber
2mm toe in rear
Neg 1.5 degree front camber
0.5mm toe in front.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
