the_big_1
posted on 5/7/16 at 08:12 PM |
Rear Hub / Diff Distance
Hi Guys,
What distance do you have / use between the Sierra diff and the hub?
Smoking Frog
posted on 5/7/16 at 09:07 PM |
Sorry, not got that measurement, but I do have a overall measurement of 1524mm between the two wheel mounting surfaces (MK Indy with rear discs).
1516mm for the front.
the_big_1
posted on 5/7/16 at 09:10 PM |
Is that from the disc flat surface where the wheel would mount?
Many Thanks!
Smoking Frog
posted on 5/7/16 at 09:25 PM |
Many Thanks!
Yes! You're welcome.
DJT
posted on 6/7/16 at 02:14 PM |
My driveshafts are unequal lengh, so I assume the measurements differ, i.e. diff is not symetrical about the centreline of the car.
http://tigeravonbuilddiary.blogspot.com/
