Author: Subject: Master cylinder query
J222jra
posted on 11/8/16 at 10:05 PM Reply With Quote
Hi I'm wondering if you could give any guidance regarding the size of master cylinder I require.
 On the front I have wilwood midilite calipers  (247mm setup).  On the rear I have a mk2 escort axle with drum brakes which have 17.8mm pistons.   The car doesn't have a servo.
Space is limited so I need something nice compact.  The one cylinder will be used for the whole braking system.
What bore size would you recommend?
Any help would be much appreciated.
Kind regards
James
