Author: Subject: squeaky brakes!!
Craig81
posted on 28/12/04 at 07:35 PM Reply With Quote
squeaky brakes!!
hi all,
as the title suggests, my breaks sqeak alot once they are warm. The brakes are just the standard cortina type with the solid discs etc. The discs and pads are new, but were only cheep unipart items. What should i try changing first??
cheers
craig
tractorboy
posted on 28/12/04 at 07:40 PM Reply With Quote
hello mate i'd hazard a guess at a sticking piston on the caliper. This is not allowing the pad to return to its resting place clear of the disc.
Rob Lane
posted on 28/12/04 at 08:01 PM Reply With Quote
Have you got the anti-squeal shims fitted ?
You could also try a small amount of "red brake grease" around rim of pistons to back of pad contact.
Craig81
posted on 28/12/04 at 08:31 PM Reply With Quote
rob, thanks for reply
tractor boy, Hello mate how r ua. Hope youve had a good christmas.
My breaks only sqeak when i press on them, but only when ive got them hot. I wonderd if it might be the cheep pads that are at fault. Was considering changing them and also may be swapping for drilled discs! What do u all reckon???
Toolbox_USA
posted on 28/12/04 at 10:45 PM Reply With Quote
Brake rotors might be glazed over.
If they have a really shiney surface, they usually will squeek when hot.
My Jag did that until I turned the rotors and went with semi-metallic Ferodo pads while I was at it.
Jeff
posted on 29/12/04 at 08:15 AM Reply With Quote
Clean the discs and pads with fairly coarse grade abrasive emmery or production paper ---- 80 to 100 grade.
Make sure you have anti squeal shims fitted.
Lightly grease shims, pad back plates and edges with "Coppaslip"
If that dosen't work fit better "OEM quality" pads (Even Rover didn't accept Unipart brake pads and shoes as meeting OEM spec for warranty replacements).
OEM spec pads generally have a spcial thick coating on the rear of he pad that acts as an nti-squeal mearsure.
