r1_pete
| posted on 3/9/16 at 05:54 PM |
Small diameter Brake Servo research....
For my 944 V8 conversion, I either need to use a remote servo, find a small diameter direct servo, or go unassisted.
My preference is a small diameter direct servo, does anyone know of cars which use a small diameter servo I could research for suitability.
Cheers.
Pete.
froggy
| posted on 4/9/16 at 01:46 PM |
I had the same issue with my car having no room to package a decent sized servo in the engine bay and ended up using an e30 bmw pedal box which has a
bell crank set up to put the servo on the n/s either in the bay or inside the car . I used a normal 11" servo from a Saab but the stud pattern
on the bracket will take most servos . Cbs list a dual circuit remote unit but it's a few hundred quid
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
| posted on 4/9/16 at 04:18 PM |
Have a look at some of the Japanese servos , I've a feeling a Micra one is pretty small?
Shooter63
| posted on 5/9/16 at 07:53 PM |
Classic mini ones are small, the proper cooper s from the 60s was a remote
Shooter
loggyboy
| posted on 5/9/16 at 10:29 PM |
How small does need to be?
Mistral Motorsport
