Mash
| posted on 6/9/16 at 04:18 PM |
New studs too long......
Hi folks, when I got my new Indy home earlier in the summer, I discovered that the previous guy had been running it with pretty short (probably
original Sierra) studs.
So I decided to buy some longer ones from Burton, and after some consultation on here, went for 63 mm ......
Anyway, finally got around to getting some new wheels, Catering van ones, and trial fitted them today, together with one of the new studs:
[img]
  Front
[/img]
[img]
  Stud protruding
[/img]
I have about 10 mm protruding, will I get away with that, or do I need to cut them down ? Also, they are a smaller offset than my previous wheels, and
the rears stick out a bit:
[img]
  Rear
[/img]
[img]
  Rear protruding
[/img]
Will I get away with that, as if I fitted wide arches they would be way too wide ?
ian locostzx9rc2
| posted on 6/9/16 at 04:49 PM |
Better to be to long !
loggyboy
| posted on 6/9/16 at 05:30 PM |
No technical reason why they are too long. Only aesthetics but they arent obvious.
I suppose it might be annoying having to turn them more times when removing!
Mistral Motorsport
theduck
| posted on 6/9/16 at 05:37 PM |
Are they the right size tyres on the back? They look to have a fair amount of stretch.
gremlin1234
| posted on 6/9/16 at 07:25 PM |
they may fall foul of iva exterior projections
quote: 12. Any protrusion of a wheel, wheel nut, hub cap, or wheel disc from the wheel rim must be at least blunted.
loggyboy
| posted on 6/9/16 at 07:45 PM |
Assumed car was on road... i suspect correctly.
Mistral Motorsport
gremlin1234
| posted on 6/9/16 at 07:55 PM |
quote: Assumed car was on road... i suspect correctly.
yep, but anyone doing a build needs to be aware of it ;-)
edit: as a technical reason.
[Edited on 6/9/16 by gremlin1234]
Mash
| posted on 6/9/16 at 09:31 PM |
cheers guys
Yes it's on the road, but I was concerned that it may be an MOT problem.
tyres are 205/50 13s on the rear on 8 inch rims so they are a size narrower than they ideally should be. I aim to go up a width when I replace them.
theduck
| posted on 6/9/16 at 09:35 PM |
Ah ok, stretch looks more than that in the photo.
