craigdiver
| posted on 7/9/16 at 03:41 PM |
Will these wheels be suitable.....
Will these mk1 ford focus zetec wheels fit a standard sierra based locost(front)/haynes(rear) suspension setup?
http://m.ebay.co.uk/sch/i.html?_nkw=322250603797
Thanks in advance
[Edited on 7/9/16 by craigdiver]
mcerd1
| posted on 7/9/16 at 03:46 PM |
yes but the offsets are ET52.5 not ET35 to 38 so you may need spacers ~15 to 17mm thick
btw I've got a set of these exact one going spare and only the other size of the forth
[Edited on 7/9/2016 by mcerd1]
craigdiver
| posted on 7/9/16 at 03:51 PM |
What ford uses 15" wheels with an offset of ET35 to 38, would rather not use spacers if I could help it?
Please tell me it wasn't just the Sierra ;-)
mcerd1
| posted on 7/9/16 at 04:06 PM |
sorry edit that - some sierra's went as high as ET41 (still a bit off ET52.5 though)
the only sierra I know that came with 15" alloys was the 2wd cossie (sierra's are mostly 14" alloys from memory)
some fiesta's (90's onwards and the others on the same platform, KA, B-max, etc) may have what you want - but a lot of the newer ones seem
to be ET47
be careful if using sites like this:
http://www.wheelfitment.net/ford
or this:
http://www.wheelfitment.eu/PCD/4x108/63.4.html
several of the offset ranges listed on both of these are not correct, and even the ones that are may only be for one model / wheel size...
Mash
| posted on 7/9/16 at 05:20 PM |
Mondeo I think,
.....as it happens I have a set going cheap in the for sale section
ETA Although, to be fair the ET is 40
[Edited on 7/9/16 by Mash]
