Author: Subject: Valve caps stuck on! Can't pump tyres up
mikeb
posted on 8/9/16 at 01:10 PM Reply With Quote
Anyone got a good tip, the wheels and tyres I bought had some very nice metal valve caps on but they wont shift to pump the tyres up. They even have a hex head on them but they won't budge.
Any tips before I attack them with a dremel and a cutting disk?
Mike
posted on 8/9/16 at 01:26 PM Reply With Quote
Have you tried a set of mole grips or large pliers to loosen them?
I guess new valves are cheap enough, but the risk of damage seems high if resorting to cutting them off.
Bluemoon
posted on 8/9/16 at 01:38 PM Reply With Quote
little heat (hot air gun..) would be my first attempt.
loggyboy
posted on 8/9/16 at 02:16 PM Reply With Quote
Some have small allen grub screws holding them in.
[Edited on 8-9-16 by loggyboy]
Mistral Motorsport
bi22le
posted on 8/9/16 at 02:28 PM Reply With Quote
I was just about to say this!!
If they are nice they have security grub screws to stop people robbing them!!
Please read my ring story:
posted on 8/9/16 at 03:21 PM Reply With Quote
I suspect you pay handsomely for BMW "M" valve caps so why not pay a little more and have grub screws. What a bugger if you lost the Allen key
ian locostzx9rc2
posted on 8/9/16 at 03:39 PM Reply With Quote
A little heat may work but metal valve caps are a real pain and you end up cutting them off .
sdh2903
posted on 8/9/16 at 03:46 PM Reply With Quote
Metal valves are the work of satan. They just corrode solid. My Ickle fiesta ST came from the dealer with stainless valves which are now starting to cause corrosion on the alloys themselves. Went to see ford the other day and they said I shouldn't have fitted metal valves. They didn't know where to look when I said you sold them to me like that.
When you do get them off swap them back to plastic asap.
shindha
I had this they were a free set (made of aluminium) from a body shop mole grips, heat, WD40, plus-gas and no amount of foul language would shift them took wheels off the car and to a tyre place replace all 4 valves and used plastic caps ever since.
[Edited on 8/9/16 by shindha]
posted on 8/9/16 at 04:27 PM Reply With Quote
Plastic have always worked fine for me on cars, bicycles etc. "if it aint broke don't fix it".
jacko
posted on 8/9/16 at 06:17 PM Reply With Quote
I had this on my car i carefully filed one side and split the caps off i had to do all 4 caps
stop filing when you see the brass tread showing
jacko
posted on 8/9/16 at 07:30 PM Reply With Quote
Seen it loads of times on cars equipped with tyre pressure monitoring systems where the valves have a sensor built in , some cost upwards of £50 a time
snapper
posted on 8/9/16 at 08:27 PM Reply With Quote
What you need guys is a little lubrication....
A dab of clear grease or even delicately applied copper grease
I eat to survive
I drink to forget
benchmark51
posted on 8/9/16 at 08:36 PM Reply With Quote
get the missus to take 'em off
owelly
posted on 8/9/16 at 10:46 PM Reply With Quote
Kettles of boiling water and gently nip the caps from all three directions. Plenty of patience and they'll come off.
http://www.ppcmag.co.uk
posted on 9/9/16 at 08:20 AM Reply With Quote
Mike
I hope you've managed to remove the caps!
If you want some I have some spare plastic caps in my tool box and given a postal address would let you have them for free
ETA...they're not fancy schmancy "M" caps, just plain black ones - hope that's not an issue for you.
[Edited on 9/9/16 by nick205]
Matt21
posted on 9/9/16 at 11:43 AM Reply With Quote
Mole grips on the valve body and a spanner on the cap. It doesn't matter if you mash the valve body up as they're useless as it is anyway.
When you put them back on, use some grease.
Instagram: @matt211988
Photobucket
My YouTube
ravingfool
posted on 9/9/16 at 12:24 PM Reply With Quote
encouraging to hear I'm not the only one to have experienced this!
I carefully took a junior hacksaw to the caps until I was able to split them. Bit awkward around alloys but worked.
A dremmel would also work but you'd want to take it slowly.
I really didn't want to damage the valves when I did this as I discovered 3 out of 4 caps had corroded on after a period of particularly bad weather when I was doing my final checkover of the car the night before a drive to the alps!
Any more cars that come with daft metal caps will be switched to plastic in the future!
nobrakes
posted on 20/9/16 at 12:48 PM Reply With Quote
Does anyone remember the metal Schrader caps that had a 'key' on the top so you could remove the valve cores? They used to make a plain topped version too, I never had either of these seize in place. Maybe that was just down to the plating they used?
owelly
posted on 20/9/16 at 04:05 PM Reply With Quote
They were/are brass. I still have a few kicking about.
Mr Whippy
posted on 20/9/16 at 06:14 PM Reply With Quote
Yeah had this with bling metal caps, corroded onto the valve thread so bad the valve tore off! Never used metal ones again after that.
