micksymonds
posted on 10/9/16 at 09:19 AM |
Hi Spec or Wilwood, that is the question??
Assembly of all of the part to rebuild my Fury is progressing well...
I have at last been able to identify upgrade options for the brake system from both Wilwood & HiSpec, but am interested to get views on which
direction to go in?
Mick
posted on 10/9/16 at 09:36 AM |
There is a recent post on the forum regarding HiSpec customer service that may be of help
posted on 10/9/16 at 10:13 AM |
Wilwood, got mine through Rallydesign, excellent service. Good service direct from EBC on suitable pads as well.
Daf
posted on 10/9/16 at 10:41 AM |
+1 Got mine Wilwood ones through Rallydesign - spot on service and the brakes are brilliant quality.
Shooter63
posted on 10/9/16 at 11:19 AM |
Another vote for wilwood here, I've got the dynapro on the front fitted with hawk dtc30 pads, they are a bit iffy from dead cold but still work,
once they get a bit on temp into them, they are almost like having a servo fitted. I found the polymatrix pads from wilwood to be junk, but others may
disagree.
From what I've heard and read the hi specs are good but the service is pretty average, so if you go for the hi specs order them from a dealer
and let them have the grief.
Shooter
Toprivetguns
posted on 10/9/16 at 11:25 AM |
+2 Wilwoods from Rally Desgin, fantastic calipers.
[Edited on 10/9/16 by Toprivetguns]
Only drive as fast as your angel can fly... !
raptor700
posted on 10/9/16 at 11:56 AM |
I have had hi spec and now got Wilwoods, Wilwoods are lighter and the rears are 4 piston , price is good and buy from rally design. I have the feroddo
2500 pads awesome on track and good on the road too.
I have the pedal box to match and quality is excellent.
sdh2903
posted on 10/9/16 at 11:58 AM |
If you can handle being to made to wait an age and be lied to then go hi spec. It was me who wrote the recent post
http://locostbuilders.co.uk/forum/52/viewthread.php?tid=205766
They are now lying to me and f***ing me about with the refund with 3 separate excuses why they haven't given me my money back. I'm just
letting the bank deal with the lowlife cowboys now.
Rally design will be getting my money when I get it back. Always helpful and knowledgeable and most stuff is on the shelf.
bi22le
posted on 10/9/16 at 01:47 PM |
I have got willwoods powerlites and they seem very good.
The only negative i can see (which may not be that much of a negative) is they are a special pad unique to them. There is plenty of choice out there
but this did not help when I was at Mallory Park (near Leicester) and could not find ANY stockist within an hours drive.
Also the bleed nipple is a funny size, again probably not unique to Willwood but was for me as I did not have the correct tool in my rather large
collection.
Not sure if Hi Spec use a sierra pad or not, its just something that has supprised me and caught me out.
I know that a lot of classic Ford guys use Hi Spec but there is also a little negative news in their circles as well. For me, having Hi Spec about a
mile down the road, I would consider using them as they are so local.
Please read my ring story:
MadMaxx
posted on 10/9/16 at 02:04 PM |
collection.
Pads for Hi Spec are the same as for Elise
[Edited on 10/9/16 by MadMaxx]
My re-building diary:
http://www.llcc.it/YetAnotherForum.NET/default.aspx?g=posts&t=13448
daniel mason
posted on 10/9/16 at 03:00 PM |
Depends on budget and caliper mounting.
The radical branded capliers on the radical websites are actually a hi spec lug mount, 4 pot race caliper. With performance friction pf01 pads they
are like nothing else I've experienced. A big Step up from wilwood but very expensive
[Edited on 10/9/16 by daniel mason]
sdh2903
posted on 10/9/16 at 04:43 PM |
If you decide to go for hi specs the best advice I would give is to buy from a reputable 3rd party. That way you don't have to deal with the
muppets direct. I suspect a decent reseller will get much higher priority than your average Joe buying direct.
I would stay away from the ultralight calipers as there have been lots of reports of them flexing. Theres no doubt as Dan says they make some decent
gear but for me the diabolical service means I will never use any of their products.
daniel mason
posted on 10/9/16 at 04:48 PM |
The radical big brake kit is absolutely mega!
