Ugg10
| posted on 12/9/16 at 12:31 PM |
Pattern 4 pots any good ?
Seen these on ebay - TO CLEAR FRONT PAIR OE QUALITY BRAKE CALIPERS IMPREZA 2.0 TURBO INC WRX BC9246
They look like pattern versions of the Subaru Impreza calipers for 293mm x 26mm discs. Anyone got/seen these and got views as to how good/bad they are
Looking to potentially put them on 260mm x 24mm discs with brackets to Escort uprights, looks like a very cheap (possibly too cheap) way of getting 4
pots ??? comments ???
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
loggyboy
| posted on 12/9/16 at 12:38 PM |
Assuming they arent alloy, whilst they may give some braking upgrade, certainly wont be lightweight.
Mistral Motorsport
Ugg10
| posted on 12/9/16 at 01:21 PM |
Thanks for the info, I suspect they are cast but I am currently using Sierra XR4x4 single pots (Caprisport GTR260 kit) which are cast iron and are 4
KG each without pads and mounting bracket so probably close to 5KG per wheel. This looks like it has less material in it than the ones I have. (260mm
vented discs I have are also 5.6kg each!). Note - this is on a Ford Anglia but as this only weights around 750kg the Locost solutions are not a bat
match. Looking for the best set up for 14" minilites (ET26 or18)with as little layout as possible. The Fiesta ST150 discs look interesting at
278mm but they are not as high as the ones I have (45 vs 55 mm).
[Edited on 12/9/16 by Ugg10]
keljon
| posted on 12/9/16 at 03:15 PM |
i fitted those to an impreza i had a few years back, they are a great price for brand new calipers but yeah cast not alloy
