bigandy
posted on 30/12/04 at 04:58 PM |
Suspension bush bolts
Afternoon all!
I was just wondering what the general consensus of opinion was regarding the bolts used to bolt up the suspension arms. I know they are a clamping
device only, not a pivot, but should they be greased on assembly or not?
Just wondering
Dammit! Too many decisions....
craig1410
| posted on 30/12/04 at 05:02 PM |
I have because I want to avoid any corrosion between the crush tube and the bolt. I used copper grease as an anti-sieze rather than lubricant for this
reason.
Craig.
bigandy
| posted on 30/12/04 at 05:26 PM |
Aaah, it seems great minds think alike. I initially thought that copper grease would work between the bolt and inner bush tube thingy, just to stop
any binding/corrosion.
It's good to get a little reassurance every so often!
Now, I just need to fins somewhere to get some 0.5mm M12 washers! anyone got a link?
Northy
| posted on 30/12/04 at 06:10 PM |
Not again....
Graham
bigandy
| posted on 30/12/04 at 06:26 PM |
Ah. Apologies, even though they look like some top quality worms though!
craig1410
| posted on 30/12/04 at 08:53 PM |
I must admit, I had forgotten about the long running debate on this subject a while back. However, if it is the one I'm thinking of then it was
more about whether the crush tube should pivot on the bolt or not. I think most of us came to the conclusion that the bolts should be tightened and
thus the crush tube does not pivot in relation to the bolt and thus the grease is only useful for anti-sieze/anti-corrosion.
QUICK, put the lid back on the can o worms before any more get out!!
Craig.
Northy
| posted on 30/12/04 at 09:09 PM |
Graham
Rorty
| posted on 31/12/04 at 03:35 AM |
quote: Originally posted by bigandy
Afternoon all!
Just wondering
Ordinarry engine oil was used by the masses for years as an assembly lubricant, but the drawback is that it's messy during assembly, and will
attract dirt in service.
ALL fasteners should be lubricated and the modern dry lubricants are ideal for the average handyman.
Fastener manufacturers sometimes use various cold/baked on dry lubricants which is good, but not all and not all the time.
If you can't find a proprietry dry lubricant, you can easily make your own dip by disolving a little candle or bee's wax and graphite or
molydbenum disulphide in some turps. This will dry on the surface of the fasteners after dipping them and doesn't wear off easily when handling
them.
Stainless fasteners require a bit more attention as they can gall causing reliability and dismantling issues. Again, there are proprietry anti-galling
pastes and coatings about.
Just came across this crowd in the UK who make various coatings: Teer Coatings.
[Edited on 3/1/05 by Rorty]
Cheers, Rorty.
NS Dev
| posted on 31/12/04 at 02:35 PM |
The suspension should most certainly NOT pivot on the bolt!!!!!!!!!!!!!!!!
The bush should swivel on the tube!!!!!!! The tube should be pinched tight in the bracket, and the bushes then have a small cheek clearance against
the bracket at each side. If you shim the bushes in the bracket, the shim needs to space the tube and bush together, not just the bush.
| posted on 31/12/04 at 03:32 PM |
on that best-forgotten thread, everyone agreed that the bush pivots on the crush tube. The source of contention was whether the bush should be
slightly longer than the crush tube (ie pinched by a few thous) or slightly smaller, and free to wobble.
I personally couldnt care less, and i do apolloguise for bringing the matter one step nearer to the surface...
maybe if we could all agree not to comment either way on this matter, and let newbies just search and find the thread themselves? either way...
craig1410
| posted on 31/12/04 at 06:13 PM |
Joel,
Yes I am one of those who agreed 110% that the bolt should be tight but I do recall someone (or more than one) thought that having the bolt not fully
tightened was a valid solution.
IIRC, it was not long after I joined this forum and I can't remember who argued this particular point and whether they were just making an
obscure point which may be valid in 0.1% of scenarios. This does sometimes happen as many of you will be aware. My worry is if a Newbie (like I was
back then) comes along and misunderstands the unique scenario where a given obscure solution IS perhaps valid and then uses that solution in a more
standard scenario.
Anyway, my advice is to take all advice on any forum as if it was from some stranger you just bumped into in the pub. You'll soon get to know
who's advice you can trust and that is when the forum really becomes useful.
On the spacer washers, I am using large 32mm zinc plated penny washers (from Screwfix) which I think are around 1.4mm thick each. They have a 10mm
centre hole to match my bolts and as luck would have it they are almost exactly the same outer diameter as my Nylon bushes. I have a total of four
washers fitted on each bolt, two each side of the bush, to enable me to adjust my castor angle. I have designed out the book error so I should have
about 5 degrees to start with and can vary this from something like 3 degrees to 8 degrees by moving washers around on both the top and bottom
wishbone. I have also applied some copper grease between the washers so my suspension has a nice fluid motion as the washers tend to slip rather than
the nylon to washer interface. I did ensure that my crushtube was 0.5mm longer than my assembled bushes as well otherwise it was a bit tight.
Craig.
Rorty
| posted on 31/12/04 at 08:45 PM |
quote: Originally posted by craig1410
I have also applied some copper grease between the washers so my suspension has a nice fluid motion as the washers tend to slip rather than the nylon
You could have used tabbed washers and bend the tabs over so they lock into a notche filed into the under sides of each bracket (BTDT).
Alternatively, you could pin or screw the washers through the sides of the brackets.
Cheers, Rorty.
stephen_gusterson
| posted on 1/1/05 at 01:16 AM |
i specifically remember at least one person strongly arguing the bolt could be a pivot........ not me btw
atb
steve
Rorty
| posted on 1/1/05 at 01:43 AM |
Notice how I've avoided the mention of b@lts being used as piv@ts, because as sure as I do, That Certain Person will launch another assault on
me. Good entertainment for a while, but his limited kerbside vocabulary has become boring.
Meanwhile, I've been a really good boy and just stuck to the original query and avoided several peoples attempts to kick off another manic
bombardment.
Let's wait and see if he can resist the temptation.
Cheers, Rorty.
Cita
| posted on 1/1/05 at 08:27 AM |
steve
Putting some oil on the fire Steve?
Rob Lane
| posted on 2/1/05 at 07:56 PM |
Don't care either way you fasten them BUT I will say this, having now dismantled two complete sets of wishbones and trailing arms from two cars,
put copper grease on the bolt shank before assembly. Not on threads otherwise locknut is lubricated. Put some on final exposed threads when tightened
to add a bit of rust prevention.
My car has to have the bolts cut through with a hacksaw to free the wishbones. I did not use copper grease and the bushes are well seized onto bolt
shaft !!!
The new project car has been stood in a dry garage for 12 years after being on the road for 1 year. All bar 4 bolts were copper greased, guess which
4 bolts had to be sawn through? The 4 had seized onto bolt shank, believe me they just will not free withought damaging the bolt and bracket.
[Edited on 2/1/05 by Rob Lane]
stephen_gusterson
| posted on 2/1/05 at 07:58 PM |
steve
no.... just pointing out that everyone didnt agree
atb
steve
Cita
| posted on 2/1/05 at 09:18 PM |
OK
bigandy
| posted on 3/1/05 at 03:41 PM |
A healthy dose of copper grease between bolt and bush (inside the crush tube bit) it shall be then.
If there is one thing more annoying than getting your knob caught when aipping up your jeans, it is siezed bolts...
Cheers folks!
