Shooter63
| posted on 18/9/16 at 09:19 PM |
What diff Ratio?
At the moment my car is running a 3.9 diff with 185/60-14 wheels/tyres, with the type 9 5th gear ratio this allows me to cruise quite nicely at
around 80-85mph without the engine revving it's nuts off.
My new tyres/wheels will be 195/50-13, obviously the revs are going to be quite a lot higher for the same speed, do you guys think it will be worth
changing to a 3.54 diff ratio or will this kill the acceleration
Shooter
snapper
| posted on 18/9/16 at 09:40 PM |
If your running a 3.9 I assume from this its a Sierra diff therefore your next higher option is a 3.6 (3.54 is a live axle ratio).
There are some great gear ratio calculators that let you try different wheel/tyre/gear ratios
Much better than guessing
I eat to survive
I drink to forget
richard munnis
| posted on 18/9/16 at 09:53 PM |
Look up the Westfield speed calculator and just put in diff ratio tyre size gear ratios and it works it all out for you
Shooter63
| posted on 19/9/16 at 06:35 AM |
Thanks for that, it seems the 3.54 diff will work perfectly.
Shooter
