Author: Subject: Split rim wheels, need to add 1" to the rear lip
mark chandler
posted on 30/9/16 at 07:35 AM Reply With Quote
I have a set of Alessio 18" split rims, which I want to widen by 1/2" - 1" on the rear lip, the problem is they stopped making these 20 years ago so getting a new lip is not going to happen.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/643041-porsche-speedline-alesio-18-wheels.html
So would it be possible to make a spacer to add the extra width, and if so where would I get the material, cast a ring and machine?
Car currently has 245/40/18 tyres and I want to increase the rear to ideally 255/35/18 or 265/35/18
Thoughts?
loggyboy
posted on 30/9/16 at 07:45 AM Reply With Quote
I suspect it will be cheaper and easier to sell the ones that dont fit and replace with a current set that's spec'd exactly as you want. Is there not similar style available still in production?
Also whats the current width? as a 9" suits a max of 265 profile.
[Edited on 30-9-16 by loggyboy]
Mistral Motorsport
mark chandler
posted on 30/9/16 at 08:25 AM Reply With Quote
Current width is 8"
I like these wheels, they are a rare early fit on DB7's so want to keep them if possible.
Plenty of jaguar options out there should I go another way, I am trying to reduce oversteer on the limit and improve 1/4 mile times, r888r's are looking favourite to help me along as well
v8kid
posted on 30/9/16 at 09:31 AM Reply With Quote
I bought a set of 13 rims from a sidecar racer and one of them presumably the sidecar had a nylon spacer to widen the rim. The chap swore blind it held air but I have my doubts.
Easy enough to machine on a lathe using a faceplate from 1lnch plate and silicone or polysulphide the assembly
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Ugg10
posted on 30/9/16 at 09:45 AM Reply With Quote
Long shot but can you get someone that does banded steels to widen them. If they are ally then this may be more difficult.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
CNHSS1
posted on 30/9/16 at 11:17 AM Reply With Quote
Image in tipton will make you new inner rims, tell them inner bore diameter, no of bolt holes (30-40 etc) and bolt hole pcd.
v8kid
posted on 30/9/16 at 01:05 PM Reply With Quote
Image only do spun rims I presume these are cast?
mark chandler
posted on 30/9/16 at 06:39 PM Reply With Quote
That sounds good, as far as I know these are spun, they were phenomally expensive as an option, they fragile anyway and very thin
[Edited on 30/9/16 by mark chandler]
