Author: Subject: NODIZ ecu car not running?
ProjectSi
posted on 23/10/16 at 09:36 PM Reply With Quote
So, I've been running my car on factory ford esc management for the time being and despite some misfiring on idle/sticky rev issues it ran okay. Soon as it was driven the car went pretty well, I have today however wired up my Nodiz Pro ecu and it now runs like a bag of spanners. Pretty much any throttle input kills the car, I connected the tps and calibrated to see if this would help but it hasn't. The Motorsport electronics page gives a full guide to setting it up but one issue I've found is I can't alter the trigger wheel setting on the ecu and wondering if this is the issue I'm having. The Nodiz ecu seems to be sparking at half time than the old Ford esc stuff was and I'm wondering if that's maybe because its set to the wrong trigger wheel? Anyone else had issues like this before?
JacksAvon
posted on 23/10/16 at 09:57 PM Reply With Quote
Give the boys at Motorsports Electronics ring in the morning. I have always found them very supportive.
I run a Nodiz on my 1800 Zetec on carb's.
It not only worked straight out of the box but also raced strait out of the box, the map was that good.
It was a 4 hour race at Snetterton that I completed with a mate who was running a ST170, also running faultlessly on an 'out of the box' Nodiz.
[Edited on 23/10/16 by JacksAvon]
The sickness started in 2001 with a Robin Hood 3A, Prelit Westy,Tiger Cub, Tiger Avon, Tiger R6, 16v Mini, Sylva Fury Fireblade, Westfield Sei, Mallock Mk11, Fireblade Locost, Tiger Avon, Procomp LA Gold, Mk26 Mallock...........and now a Mk18 Mallock.....LR750, Vandiemen FX02
johnemms
posted on 24/10/16 at 10:08 AM Reply With Quote
Stick a strobe light on it..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
johnnybizzle1986
posted on 24/10/16 at 11:46 AM Reply With Quote
Are you using a trigger wheel or the standard Crank sensor? it should be set 90 before TDC sounds like its set 90 after like I did with mine there fore it was 180 degree out. I was able to start again a re position the trigger wheel.
Regards Jon
mtechmatt
posted on 24/10/16 at 04:42 PM Reply With Quote
They indeed do work out the box - the trigger change mode was added to the manual and only works on NODIZ delivered in the last 2 weeks....
If you like we can have it back under RMA to test? Please use a support ticket or phone to contact us as we do not often check forums! (And may not reply on here again if we miss it!)
Matt
V4 Engine Management System | Online Shop | Rolling Road Tuning | Motorsport Preparation | Engine Packages | Throttle Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
ProjectSi
posted on 24/10/16 at 06:16 PM Reply With Quote
I'm still using standard Ford flywheel and crank sensor, but it seems to be firing at about half time as opposed to the standard esc stuff hence my thinking that the trigger setting is incorrect. Does this sound like symptoms of incorrect trigger setting or would it simply not run at all if this being the case?
Ugg10
posted on 24/10/16 at 06:42 PM Reply With Quote
Are you getting spark to all four plugs, the coil pack fires two at a time so if one connection is lost it will be running on two cylinders, or are the two coil pack wires crossed? Just a thought.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
ProjectSi
posted on 24/10/16 at 07:12 PM Reply With Quote
Yes I am, but as I said they are firing at about half the speed the standard esc was firing them. Leads are untouched and was running spot on with esc. It's as if the ecu wont fire the spark fast enough when throttle, fuel and air are applied and thus floods the engine to stall.
swanntech
posted on 21/11/16 at 07:35 PM Reply With Quote
nodiz
sounds like the ecu is set up for Vauxhall trigger wheel
ProjectSi
posted on 21/11/16 at 11:01 PM Reply With Quote
That's what I thought, I'd imagine it would run on vauxhall trigger setting but never run right, is the only way to alter the trigger setting through the motorsport electronics software do you know?
swanntech
posted on 24/11/16 at 07:53 PM Reply With Quote
nodiz
set mine up to Vauxhall trigger wheel using computer been fine but it wont run sierra rev counter
