the_big_1
posted on 9/11/16 at 09:53 PM |
Sierra Diff Oil Seals
Hi Guys,
Does anyone have pictures of which way around the three oils seals are fitted in a Sierra Standard Diff?
Cheers!
mcerd1
posted on 9/11/16 at 10:09 PM |
the_big_1
posted on 10/11/16 at 07:16 AM |
Hi ya,
Thanks for that but that also doesn't show which way around the oil seals go???
I mean is the flat face to be facing out or in??
Is the spring that holds the seals to the shafts inside or outside??
Cheers!
CosKev3
posted on 10/11/16 at 08:17 AM |
Who removed them?
Pretty sure the driveshaft ones go the normal way seals go,spring inside.
But the the front oil seal where prop attaches to goes in the opposite way around.
the_big_1
posted on 10/11/16 at 09:27 AM |
Hi ya,
I thought they where that way too but trying to make sure lol
posted on 10/11/16 at 09:44 AM |
Pretty sure they are fitted with the spring innermost to grip the drive shaft...
mcerd1
posted on 10/11/16 at 10:44 AM |
^^ thats the normal way for any rubber oil seal of this type
[Edited on 10/11/2016 by mcerd1]
the_big_1
posted on 10/11/16 at 11:32 AM |
Perfect!!!!
Anyone have a pic of the input shaft seal, just to be 100%
Cheers!
posted on 10/11/16 at 12:33 PM |
No, didn't replace that seal. Hoped it was OK and it was (never leaked).
mcerd1
posted on 10/11/16 at 12:39 PM |
^^ re-setting up the diff is a bit more involved if you want to do the input oil seal - see the procedure for removing and refitting in the manual
above
the_big_1
posted on 10/11/16 at 12:48 PM |
I have the seal out and a new seal ready to go back, easy to do but need to know which way around lol
DJT
posted on 10/11/16 at 12:56 PM |
When I replaced my pinion seal I double checked with the seal supplier and he confirmed "spring inside".
http://tigeravonbuilddiary.blogspot.com/
the_big_1
posted on 10/11/16 at 01:12 PM |
Great stuff!
Thanks guys!
CosKev3
posted on 10/11/16 at 02:37 PM |
above
You don't need to reset the diff to change the seal, as that is done with the inner nut.
To do seal you just remove the flange nut and flange
mcerd1
posted on 10/11/16 at 04:20 PM |
above
^^ that would make sense
I keep thinking he'll be changing the bearings too for some reason.....
