Wolf1e
posted on 4/1/17 at 10:51 PM |
What size master cylinders to use
Hi guys
What size master cylinders would you recommended. I'm using a wilwood top mount pedal box. My brake set up is as follows: I'm running
wilwood 4 pots on the front, sierra callipers on rear.
And what size would you use for the clutch master cylinder?
Currently I have 2: 0.625 and 1: 0.7 cylinders
Ian
rodgling
posted on 5/1/17 at 04:36 PM |
There's a lot of variables involved, and if you are using different calipers to what most people on here have then you can't just use the
same sizes as everyone else. See the discussion here:
http://www.locostbuilders.co.uk/viewthread.php?tid=201976
and use the spreadsheet, it works.
