mcerd1
| posted on 14/2/17 at 01:39 PM |
Which fittings for these flexi pipes ?
I got my flexi hoses from dax a while back, but didn't get the hard line kit from them, but now I've got a question on the fittings I need
and they aren't around to ask....
the fitting on the end of the flexi looks like this - it appears to be a standard female M10x1.0 thread and has a concave end to the line inside:
(although I can't easily measure the shape of the tapper)
Everyone else I know who got these flexi pipes also seem to have been given a male-male inline connector of some kind between the flexi hose end and
3/16" hard line (which has a M10x1.0 female end on it) like this:
is there any reason for this inline connector ? / is it actually some kind of adaptor or has it just got an M10x1.0 on each end ?
if it is just an ordinary male M10x1.0 then the only reason I can think it would be there is to save disturbing the hard line connection when the
flexi's are changed - any other suggestions ?
voucht
| posted on 14/2/17 at 03:56 PM |
The bulkhead fitting is on the female part of your flexi lines. This part is fixed (locked by the lock nut on your bracket)
On the big picture you published, there is a female fitting on the copper pipe, so they put a male-male adaptor in between to connect both female
fittings.
But considering that fittings on copper pipes are always swivel, you could do directly with a M10x1.00 male nipple on the copper pipe, and shape a
convex the seat on the copper pipe to match the concave seat inside the female bulkhead fitting of your flexi lines.
But if you already have a female fitting on the copper pipe, then you will need a male-male adaptor like on the picture you published. You will need
to know which thread and seat are in the female fitting of the copper pipe to order the right adaptor.
Hope that helps
https://vouchtroadster.blogspot.com/
https://caferacer-kawa-gpz-zx550.blogspot.com/
mcerd1
| posted on 14/2/17 at 04:05 PM |
^^ should have said - I have no copper pipe or fittings at all yet, I'll make them up to suit
what I can't work out is why dax would choose to include the inline adaptor in the first place ?
(the copper pipe kit they sold was made for them to there own specification for this car)
voucht
| posted on 14/2/17 at 05:20 PM |
Si on that case, when you make your copper pipes, just install a M10x1.00 male fitting (= male nipple), with a convex seat on the copper pipe.
R03-Cu[/ur
l] by [url=https://www.flickr.com/photos/99498333@N06/]Sylvain ROIG, sur Flickr
Yes, it would have been more logical, as we do on the Haynes Roadster, to have flexi lines witha male bulkhead+lock nut, and a female swivel on the
copper pipes or chassis side brake lines.
LogoPageWe
bPtt by Sylvain ROIG, sur Flickr
On the picture you published, there are 2 connections (female-to-male-adaptor and male-adaptor-to-female-bulkhead) when just one is actually
needed.
[Edited on 14/2/17 by voucht]
