Author: Subject: ride height
craigdiver
posted on 11/5/17 at 05:38 PM Reply With Quote
ride height
I have a lot of sump sticking out the bottom of my chassis, some of this will be removed when I rework the sump however will likely still have up to 50mm protruding. As the car will be used for touring, can I get away with fitting longer shocks to raise the ride height? Any suggestions on shock length, 15,16"? or is there a bit of ride height adjustment in the standard 14" shocks (looking at the gaz units from rally design).
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
