the_big_1
| posted on 4/7/17 at 05:44 PM |
Wheel Bearing Help
Hi Guys,
I purchased some wheel bearings of you know where, came with a couple of days.
Fitted them in the hub no problem but the shaft wont fit, seems like the bearing is too small inside.
From what I can tell there are only two types and mine is this one:
http://www.burtonpower.com/wheel-brg-kit-r-ford-sierra-cosworth-xr4x4-abs-granada-mk3-brt910.html
This is what I got as an alternative
2x WHEEL BEARING KIT REAR LH + RH FORD SCORPIO MK 1 2 GRANADA 1.8-2.9 85-97
Has the same dimentions.
I dont want to buy the Burton ones if they wont fit either??????
The old bearing is an SKF and has the following number on it:
BT1B328053-Q if that helps?
What do I do now???
| posted on 5/7/17 at 07:54 AM |
From your message it sounds like you ordered one bearing, but were delivered a different bearing - please correct me if I've misunderstood!
If the above is correct then in theory you should be able to have it exchanged for the correct bearing. However if you've already fitted it
into the hub then the seller may not wish (or be obliged) to exchange it.
To source the correct part I'd be inclined to take the old one and a ruler to a motor factors and get some help that way.
the_big_1
| posted on 5/7/17 at 07:57 AM |
Hi ya,
I measured the inside of my old bearing, 41mm as per the advertised bearings. Measured the supplied one and it measures 40mm!
jester
| posted on 5/7/17 at 10:56 AM |
looks ok to send back
If there wrong there wrong
Warranty
2 year legal warranty
QUALITY PRODUCT - NEW - READY TO FIT
NO RISK!
90 DAYS RETURN POLICY* GUARANTEED
FREE RETURN
*Our return policy terms can be found in our customer information
Just watch they dont try and charge you for shipping them back other wise you might as well keep them for what they cost
Trying to buy stuff for a Mk1 Fiesta kit car is very hit & miss for me a lot of time
| posted on 5/7/17 at 02:27 PM |
quote: Originally posted by the_big_1
Hi ya,
That's beyond "interference fit"!
Get on the phone to them and explain the issue.
the_big_1
| posted on 5/7/17 at 02:30 PM |
I have raised the issue through their issues form on their website, have pictures just in case.
Order another set from somewhere else but double the price.
