alfas
| posted on 30/10/17 at 10:48 AM |
Searching Lower wishbone for MK locost
as spare (the actual ones are still ok...but who knows what all can happen on the track), i´m searching front wishbones for my MK Locost (very early
chassis)
i´m using the below pic only as refernce to explain the dimensions:
on upper wishbone the 365mm measuremtn is 230mm..is at least this measuremtns something common?
kitcardirect
| posted on 30/10/17 at 02:14 PM |
Hi
this any good for you?
http://www.kitcardirect.co.uk/locost-bottom-front-wishbone.html
Follow Us On Facebook : http://on.fb.me/1KYgL8N
alfas
| posted on 30/10/17 at 09:16 PM |
measurements look totally different, imo.
kitcardirect
| posted on 31/10/17 at 09:48 AM |
ok sorry this must be as per the standard MK front wishbone, i thought you wanted locost, our error,
http://www.kitcardirect.co.uk/mk-indy-bottom-front-wishbone.html
The 365 mm is including the poly bushed inserted is that correct?
Total length we have from tip to tip is 395mm, and from hole centre to hole centre 337mm,
hope this helps
alfas
| posted on 1/11/17 at 12:49 PM |
its an MK locost...not indy
the measurements given are without bushes. 365 on lower, 320 on upper
kitcardirect
| posted on 1/11/17 at 12:59 PM |
ok sorry we couldn't help you
40inches
| posted on 1/11/17 at 01:04 PM |
My MK Locost chassis is a very early one, built around 1999. The new oval tubed MK Indy front wishbones fitted fine
The only difference between the Indy and Locost versions is at the rear. From my experience.
alfas
| posted on 1/11/17 at 07:22 PM |
can you take the measurements of your car´s wishbones, please and compare?
imo, MK Indy´s have a much wider front-track than MK Locost´s
