Mark100
| posted on 21/1/18 at 05:37 PM |
Brake lines st220 and sierra
So i have st220 mondeo calipers on the front and standard sierra on the rear anyone know if i can get an st set will it fit rears or do i need to sort
front and rear seprate carnt seem to see braided stainless individuals
Nickp
| posted on 22/1/18 at 07:01 AM |
Just make your own, it's simple and cheap with bits from CBS.
russbost
| posted on 22/1/18 at 10:07 AM |
It's hardly any cheaper to make your own than get custom ones made in any colour you fancy with a wipe clean pvc outer instead of bare braid
that attracts oil, dust & muck like a certain substance attracts flies!
Linky to brake hoses
You'll want m10 x 1.0 male swivels for the calipers, & probably male bulkhead for the inner ends, depending on what you have on your copper
pipes, just check you have sufficient clearance around the caliper entry points as you might need a bend on those depending on access
[Edited on 22/1/18 by russbost]
Mark100
| posted on 23/1/18 at 06:11 PM |
Thanks ill gett measureing tomorow carnt seem to find details on fitting for calipers. Want to confirm before order and havent made copper pipes up
yet so that end is easy
russbost
| posted on 23/1/18 at 06:34 PM |
With most calipers a straight male swivel is the simplest, easiest & cheapest fitting, all you really need to look at is the access to the entry
port to make sure you can get a straight run from there, best way to measure is from tip to tip of the whole hose including the unions, don't
forget to allow for lock to lock & bump/droop, it's always better to have a hose a few cm too long than one that twangs like a guitar
string!
