posted on 7/2/18 at 05:50 PM |
Using Aftermarket Dampers
Evenin' folks,
Looking for a bit of a steer regarding the suitability of using a set of dampers that I have.
The manufacturers original-eqiupment and non-adjustable damper lengths were:
Front Open 364 mm Closed 261mm
Rear Open 398 mm Closed 283 mm
The aftermarket shocks I have are are adjustable for height and rate and they emasure:
Front Open 357mm Closed 275mm
Rear Open 417 Closed 317mm
These measurements are all metal-to-metal. I guess I could trim the bump-stops to give me more length?
The vehicles have a similar weight distribution, so the valving should be fine.
Any thoughts about the likelihood of them working out?
It's Evolution Baby!
posted on 7/2/18 at 06:03 PM |
Doing the maths….
Front:
Open 7mm shorter
Closed 14mm Longer
Rear:
Open 19mm longer
Closed 34mm longer
fregis
posted on 7/2/18 at 06:46 PM |
Maybe use harder springs, so will be enough travel
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
posted on 8/2/18 at 08:59 AM |
