Author: Subject: Wilwood Powerlites with Fiat 124 Master cyl?
DavidW
posted on 30/4/18 at 07:16 PM Reply With Quote
Hi
I previously swapped to a fiat 124 master cylinder which did a really good job of improving the pedal feel on my Sierra braked Indy.
Now I’ve swapped the fronts to the Rally Design Sierra Wilwood Powerlite kit and can’t get it to work.
Although I’ve found them hard to bleed I’m pretty sure I’ve managed it but just can’t get a pedal. The master cylinder bottoms out.
Has anyone ran the wilwood setup with the 19mm fiat master cylinder? I know it’s smaller than the 22mm Sierra master cylinder.
I can can find no brake fluid weeps anywhere in the system so don’t think I have a leak.
Any ideas?
JAG
posted on 1/5/18 at 11:21 AM Reply With Quote
When the master cylinder bottoms out; do you have any brake torque at all? can you move the car? do the brakes drag??
Justin
DavidW
posted on 1/5/18 at 03:10 PM Reply With Quote
There is some braking effect when the cylinder bottoms out. I’ve noticed a very slight improvement if I pump the pedal like crazy although this is lost as soon a I release.
Brakes are not dragging.
CosKev3
posted on 1/5/18 at 05:17 PM Reply With Quote
Have you checked the unused bleed nipples are tight?
How much fluid did you lose from the reservoir swapping the calipers?
Any chance you got air into the rear brake lines?
DavidW
posted on 1/5/18 at 09:25 PM Reply With Quote
Thanks for the suggestions.
The nipples are all tight.
Plenty of fluid was lost although I did the re-bleed the rears which surprisingly were way easier than the fronts.
CosKev3
posted on 2/5/18 at 03:19 AM Reply With Quote
How far did the pedal travel with the Sierra calipers?
I've gone over to 4 pots from Sierra calipers but using a Sierra master cylinder,and although the pedal is longer now with better feel to it the increase in travel is not a lot.
So unless you had a really long pedal using Sierra calipers I can't see it being a MC size issue,must be air somewhere,especially seeing as you say pumping the pedal fast does make a bit of a brake pedal.
Rears are Sierra calipers? If so you took them off to bleed them so the nipple was at the top?
DavidW
posted on 5/5/18 at 06:29 AM Reply With Quote
To close this out it was hidden air in the rear brakes which only became apparent following the suggestion to remove the callipers to bleed.
I did find that the fiat master cylinder a nightmare to bleed as it seems to link the front and rear circuit hydraulically so air in one means air everywhere.
I could not quite get happy with the system a was worried about the the way that a leak in front or rear would seem to remove all brakes so swapped back to a sierra MC which whilst shorter, gives an easy rock solid pedal.
Thanks for the help!
CosKev3
posted on 5/5/18 at 06:52 AM Reply With Quote
Nice one
big_wasa
posted on 6/5/18 at 07:23 AM Reply With Quote
Any feed back on the calipers as I am looking at them for winter upgrades ?
DavidW
posted on 6/5/18 at 08:20 AM Reply With Quote
I’ll report back when I’ve got the rest of the car back together.
DavidW
posted on 17/5/18 at 08:57 AM Reply With Quote
I've now had a chance to try the Wilwoods on the road but not yet on track.
The pedal feel with Sierra MC is great. The brakes feel a bit more progressive vs the Sierra calliper so you can really modulate the braking power right to and from the point of locking the wheels.
Not sure I've noticed the difference in performance from the reduced weight although it is a fair bit.
I'll report back after a trip to Snetterton.
big_wasa
posted on 17/5/18 at 12:24 PM Reply With Quote
Thanks for the updates. And yes I would love to know how they are when they have had a good chance to bed in and on track.
DavidW
posted on 6/8/18 at 09:20 PM Reply With Quote
To close this off....
Wilwood powerlites, mintex 1144 pads on front, standard Sierra disks on rear and Sierra master cylinder. Baking hot Snetterton..
Compared to the Sierra brakes up front these seem like a significant upgrade on track even compared to Sierra calipers 1144s and Fiat m/c.
Much better feel, so much power and very progressive.
Definitely a worthwhile upgrade.
big_wasa
posted on 7/8/18 at 07:19 AM Reply With Quote
On the upgrade list they go, thanks for the updates.
