Lotusmark2
| posted on 17/1/05 at 10:03 AM |
centre take off rack
Does anyone know of a manual steering rack with a centre point take off for the steering column? (apart from a porsche 911 £125 for a second hand
rack!!)
| posted on 17/1/05 at 10:54 AM |
What about something else rear engined like a VW Beetle or camper van/Transporter or possibly one of the old Skodas?
Failing that a McLaren F1 almost certainly has one
HTH
Nick
ned
| posted on 17/1/05 at 11:07 AM |
an old mr2 or mgf?
Ned.
beware, I've got yellow skin
andyharding
| posted on 17/1/05 at 11:26 AM |
Don't think so on the MGF.
If you want to know for sure let me know and I'll go and have a look.
Lotusmark2
| posted on 17/1/05 at 11:30 AM |
If you could have a look that would be great Andy.
Mark
| posted on 17/1/05 at 12:14 PM |
The Hillman Imp pinnion was very close to centre, also a nice high geared rack, down side is the inner track rod ends are very close together ---
about 4 inches apart.
Lotusmark2
| posted on 17/1/05 at 02:16 PM |
The Imp is too far over I'm afraid.
This is what I am after.
Liam
| posted on 17/1/05 at 03:51 PM |
MR2 is not centre take off i'm afraid. All i can think of is aftermarket motorsport racks. Titan Motorsport do them for example, but probably
not all that cheaply.
Liam
ned
| posted on 17/1/05 at 03:53 PM |
is there any milage in trying to chop a rack? I know bobc i think it is shortened a rack, could one be shortened on one side? ie leave the pinion gear
alone, but cut a section out of the housing? longer track rods could then be used to make up the width Don't know about your application or how
it would affect bump steer etc.
Ned.
Cita
| posted on 17/1/05 at 04:50 PM |
I shortened a Escort rack for my single seater to get a center steering shaft.
It's an easy job and takes only a few hours at the most.
Best thing to look for is a manual steering rack which have the pinion at a right angle to the rack like an Hyundai Stellar rack.
I found a site on which the procedure for shortening such a rack was described.
Will try to find the site if you're interested.
Lotusmark2
| posted on 17/1/05 at 05:18 PM |
Hi Cita
If you could find it, that would be great.
Mark
Rorty
| posted on 18/1/05 at 03:46 AM |
From memory, Alfa Suds, Golfs, some Skodas and possibly even one or two Saabs have centre load racks.
What did the rack in the photo come out of? It looks like a production rack and not a custom one. Can you not get one of them?
How about buying an aftermarket centre load rack? I use them all the time in my buggies.
Here are a few links:
BRT
Howe
Saco
Cheers, Rorty.
Lotusmark2
| posted on 18/1/05 at 08:12 AM |
Cheers for the links Rorty
The rack in the picture is a porsche 911 rack which is great but at £125 from a salvage yard not cheap!!
Hoped to find a cheaper doner, how much are the racks in your links (average)
Mark
ned
| posted on 18/1/05 at 09:54 AM |
I wouldn't have said £125 is that bad, especially if for example you get an escort rack, faff about shortening it, then want to put a quick rack
rack and pinion in it which aren't that cheap anyway.
Ned.
Lotusmark2
| posted on 18/1/05 at 09:56 AM |
I agree Ned, its not Too bad but if I can find a cheaper option then
Dale
| posted on 18/1/05 at 05:55 PM |
Sand rail racks are qiuite cheep but narrow--12-16 inches between inner tierods. center pinion as well--I almost used one for mine as the fit was
right but was not to sure about 1.5 turns lock to lock.
Dale
Lotusmark2
| posted on 18/1/05 at 06:01 PM |
1.5 turns lock to lock is no problem for me, can you get hold of them over there and if so at what price?? (sand rails are not big in sunny England)
chrisf
| posted on 18/1/05 at 06:41 PM |
Very Cheap
Have a look here.
They may be too short for your application, though.
--Chris
Lotusmark2
| posted on 18/1/05 at 07:38 PM |
they look great but as you say they are very short.
In an ideal world I need a 25" centre to centre and 2" of movemant on the rack per rotation of the steering wheel (should equate to 1.5-2
turns lock to lock.
Simon
| posted on 18/1/05 at 08:41 PM |
DT do them
£382.57
Simon
Dale
| posted on 18/1/05 at 11:22 PM |
http://www.desertkarts.com/item80857.ctlg
Dale
Cita
| posted on 19/1/05 at 08:59 PM |
Sorry for the delay in reply Mark but i have problems with my computer.
Do a Google search for Bills Offroad Karts and than go to construction tips. This will help you further it has some good pict
this is of any help to you
Cita
