bazz81
posted on 25/5/18 at 12:51 PM |
Mk indy brake master cylinder
Where can i buy a brake master cylinder for my mk indy?
The local Ford dealer dont know Which model i need.
INDY BIRD
posted on 25/5/18 at 01:17 PM |
http://www.mksportscars.com/mk-indy-brake-master-cylinder.html?SID=pmmds3ntls0offmglj0cd47er4
theconrodkid
posted on 25/5/18 at 01:50 PM |
did MK build it, if not, what master was used ?
the place i used for brake parts was https://brakeparts.co.uk/shop/Ford
they includes pics so worth a look, they also give part / tag numbers as well.
[Edited on 25/5/18 by theconrodkid]
who cares who wins
pass the pork pies
SJ
posted on 25/5/18 at 02:29 PM |
Likely to be a Sierra 22mm cylinder, which doesn't work very well so I would swap it for something else.
bazz81
posted on 25/5/18 at 03:06 PM |
I think its a Sierra m/c but dont know. I made 3 photos but dont know hoe to upload in this topic. I added them in my photo archive, can you see them?
bazz81
posted on 25/5/18 at 03:09 PM |
What m/c do you recommend? And is this a direct replacement? The Indy is in workshop and dont think they want to convert to another system if its a
lot of work.
Slater
posted on 25/5/18 at 04:30 PM |
I have a MAC#1 ( very similar to MK) with the donor sierra M/C and donor front/rear brakes, it works just fine.
avagolen
posted on 25/5/18 at 04:35 PM |
theconrodkid
posted on 25/5/18 at 05:10 PM |
that looks like the master from a sierra, the one most people go for is a NON servo fiesta MK1, downsizing on the bore makes a huge difference to
braking performance.
who cares who wins
pass the pork pies
bazz81
posted on 25/5/18 at 05:21 PM |
s
Are the masters of a sierra al the same? M/c must be shipped to Holland so i dont like to order x-times becouse it wont fit.
Is the fiesta also a direct fit?
bazz81
posted on 25/5/18 at 05:42 PM |
https://www.ebay.co.uk/itm/FORD-SIERRA-1-6-Brake-Master-Cylinder-82-to-88-LPR-6118138-83BB2140KA-Quality/232562714820?fits=Car+Make%3AFord%7CModel%3AS
ierra&epid=18002656221&hash=item3625d168c4:g:O68AAOSw3xVaC~hf
Is this the one i need?
SJ
posted on 25/5/18 at 05:43 PM |
Aren't there any motor factors you can take it to?
As far as I know most non-abs Sierras don't have the same mc, but can probably be easily made to fit. Mine came from a 1990 1.8 cvh Sierra
Sapphire and is 22mm dia.
Any idea what the donor car was?
Stu
bazz81
posted on 25/5/18 at 05:48 PM |
I dont know the donor, i bought the car in Holland. So i think im the third owner. Car was build in the uk.
They told me i have a 3:14 diff, in what models was that diff installed.
SJ
posted on 25/5/18 at 06:43 PM |
Problem is if you don't know it was built from a single donor the bits could have come from anywhere.
If there isn't a brake supplier you can take your old one to you will have to take a chance. £50 isn't much of a risk.
Only other option is to get it refurbished. What's actually wrong with it?
SJ
posted on 25/5/18 at 06:49 PM |
This is the one mine came with:
cvh
Looks very much like yours.
[Edited on 25/5/18 by SJ]
theconrodkid
posted on 25/5/18 at 07:27 PM |
s
unfortunatly there seems to be loads of different master cylinders, there is normally a plastic tag on the body that is the ID number you need.
no idea if a fiesta cylinder is a direct fit, probably pretty close, i change mine for a FIAT 127 one, it was brilliant but took some mods to make it
fit.
who cares who wins
pass the pork pies
bazz81
posted on 25/5/18 at 09:27 PM |
cvh
Is it possible to measure the centre distance of the mounting holes, and the holes of the reservoir? so i can check it with my m/c
[Edited on 25/5/18 by bazz81]
SJ
posted on 26/5/18 at 07:00 AM |
cvh
Sorry, I swapped it for a Fiat 124 non servo mc a couple of years ago.
bazz81
posted on 26/5/18 at 08:12 AM |
Okay no problem, thx for the reply
Dick Axtell
posted on 26/5/18 at 04:44 PM |
Sierra Mcyl
If you still want to fit the Sierra mcyl, I have an old, but unused, one available. Still attached to its servo-booster, I had it for an installation
check (when still at work).
bazz81
posted on 27/5/18 at 07:24 PM |
I dont have a servo booster so will it fit ? Can you make a photo and the dimensions/measure it for me?
SJ
posted on 27/5/18 at 08:43 PM |
All Sierras had servos fitted as standard. The reason people change the standard mc on kits is because they tend to be used without servos so need a
really firm push if the Sierra mc is used
Hopley89
posted on 27/5/18 at 09:07 PM |
Wouldn’t it just be easier to get it from mk instead of trying to find the right one for your
breaks, as there is different types for different breaks!
Dick Axtell
posted on 28/5/18 at 03:02 PM |
Will be able to do so when I get back to my lock-up. Hopefully tomorrow.
sebastiaan
posted on 28/5/18 at 06:08 PM |
If it is an Indy, there is a 99% chance you need a standard sierra master cylinder. One of these should do, and they are cheap enough to take a
chance.
brake master cylinders
Good luck.
Sebastiaan (Noord Brabant)
