Author: Subject: Off the shelf handbrake cable?
jps
posted on 22/8/18 at 09:02 AM Reply With Quote
I have Sierra disc calipers but not the original cable to cut down. Is there anything which is closer to the right size I can use instead?
pewe
posted on 22/8/18 at 11:18 AM Reply With Quote
IIRC I used one from an Austin Maxi.
Oddball I know but if it works it works....
HTH.
Cheers, Pewe10
big_wasa
posted on 22/8/18 at 11:59 AM Reply With Quote
I used Austin allegro for drums. No cutting needed.
posted on 22/8/18 at 12:45 PM Reply With Quote
If you use Austin Maxi of Allegro cables you will need 2
