Avoneer
| posted on 19/1/05 at 10:41 PM |
Mk2 Escort Brake Spares
Anyone know where I can get the big rubber "gromets" for the back plates on my Mk2 Escort axle?
Pat...
Deckman001
| posted on 19/1/05 at 11:05 PM |
I need a set as well
Jason
JAG
| posted on 20/1/05 at 08:29 AM |
A picture would help - I may be able to get some for you.
Justin
Avoneer
| posted on 20/1/05 at 12:06 PM |
Will take one when I get home.
It's an oval grommet with a slit in the middle for the arm that you attach to the handbrake cable/bar.
Pat...
JAG
| posted on 20/1/05 at 01:04 PM |
ah yes - that one's almost impossible to get these days. I think Dick Axtell found some (do a search he's a member on here) but they were
a crazy price.
About £10-£15 if I remember correctly and only available from one source.
Send Dick a U2U or email.
Justin
Marcus
| posted on 20/1/05 at 07:07 PM |
Don't buy any - true Locost principle. Get a bike inner tube and cut a section about 50mm long. Slot it over the parts and hold on with a small
tie wrap.
Marcus
Marcus
Because kits are for girls!!
Mark Allanson
| posted on 20/1/05 at 07:58 PM |
I am going to try the little nipple things that go on the internal adjustable things on door mirrors. They look like they should fit with a little
adaption
| posted on 20/1/05 at 08:08 PM |
I was going to try some Tiger seal. Block the hole with it and let it set, then cut a slot in it. Try putting some grease round it to make it
removable after it sets.
