Author: Subject: Clutch cable solution
jps
posted on 15/3/19 at 06:16 PM Reply With Quote
I'd be interested if anyone has a compelling reason why this is poor solution...!
To get the run of the clutch cable I want (avoiding where one of the brake lines will go into the master cylinder) - and to get tension on the cable i've swapped the short 'angled' tube on the back of the 'Book' Haynes Roadster pedal box for a longer tube that exits squarely at 90 degrees.
The extra length and loss of the angle introduces the problem that the clutch inner cable chafes on the pedal box as it exits the tube to come down to the bottom of the pedal. So I've fitted a length of garden hosepipe 'inside' the footwell to act as an addtional length of outer cable running almost all the way up to the end of the pedal.
Pedal movement seems fine - and as the clutch inner cable is itself plastic lined - I can't see there will be rapid wear between the inner and the hosepipe outer.
There's a photo here (sorry about the size!) - the hosepipe goes the full length of the horizontal tube, so won't work loose.
posted on 15/3/19 at 06:26 PM Reply With Quote
Looking at the angle the cable goes through before going through the bulkhead I suspect it will fracture. The pedal pivot point is too low
jps
posted on 15/3/19 at 06:47 PM Reply With Quote
I am hoping it won't, the bend the cable takes to come back into the gearbox is tighter... But shifting the pivot is my plan B
AdamR20
posted on 15/3/19 at 07:19 PM Reply With Quote
I'd shift the pivot, reckon it will chop through the hose pipe in no time.
snapper
posted on 16/3/19 at 06:28 AM Reply With Quote
What he said
It’ll be like a hot knife through butter, whatever is softest will go first (the hose) followed by the clutch cable plastic on the metal then the cable itself.
There is a huge amount of pressure on the cable, you want a clean straight run from cable outer to connection points, you could cut a slot in the metal tube and pedal box to relieve the inner cable run.
I eat to survive
I drink to forget
