scudderfish
posted on 22/6/19 at 03:16 PM |
How do I get this off?
Rack Clamp
I want to replace the rubber doughnut. To this end I want to get the lower section of my steering column out as access is awkward. I've got
the bolt out of the bit that clamps onto the rack input, but I can't get it to shift. It's currently soaking in WD40. I don't want
to apply heat as there are lots of melty things around it. Any bright ideas?
Regards,
theconrodkid
posted on 22/6/19 at 03:27 PM |
try a screwdriver in the slot to spread the coupling a bit, you may need to pull the column up a bit as well to get the coupling out.
who cares who wins
pass the pork pies
posted on 22/6/19 at 04:13 PM |
Photo isn’t too clear but is it a Sierra column? If so undo the upper coupling (1 bolt then swivel the plate) that will allow the whole lower section
to move upwards
scudderfish
posted on 22/6/19 at 04:55 PM |
to move upwards
I did that but it still seems stuck fast on the splines. I think I might just have to apply more violence with a screwdriver to ease it apart.
Benzine
posted on 22/6/19 at 05:02 PM |
I used a length of metal rod and managed to tap it with a hammer from the front of the car. All depends on whether your rad etc gets in the way
though.
[Edited on 22-6-2019 by Benzine]
steve m
posted on 22/6/19 at 05:09 PM |
Ive used a ball joint spliter on my car before, similar to the attached
https://www.ebay.co.uk/p/Toolzone-8-Chrome-Plated-Short-Forked-Ball-Joint-Splitter/1736877381?iid=252276680021#UserReviews
scudderfish
posted on 22/6/19 at 05:42 PM |
Thanks for the suggestions. Once I knew it should come off, I went at it with a bit more vigor. I started off with a small crowbar and a piece of
pipe to give it a bit more length, but that just started bending. So I cracked out my biggest crowbar.
Off
A couple of heaves and it slid off Going to clean it very well and give it a coat of copper grease when it goes back together.
snapper
posted on 23/6/19 at 06:04 AM |
Personally I would use a lubricant to assemblage something you don’t want to come apart when moving at speed.
If you ever need to get it apart again you have mastered the technique
I eat to survive
I drink to forget
