Author: Subject: Rear end parts confusion
falcor75
posted on 27/9/19 at 03:56 AM Reply With Quote
I have gotten myself into a mixed parts confusion and I need a bit of help from those with more knowledge than me.
My rear diff and drive shafts are the push in kind. I also have a rear disc setup complete with hub and the splined rotor but of couse the driveshaft splined bit wont fit into the disc hub. Is the inner diameter of the drum wheel bearings the same so I can just replace the disc hub with one from a drum brake car?
loggyboy
posted on 27/9/19 at 08:14 AM Reply With Quote
No, its not as simple as that IIRC as the bearings are different and drum hub carrier doesnt have brackets for the calipers.
falcor75
posted on 27/9/19 at 08:31 AM Reply With Quote
I figured it wasnt since I couldnt find anyone thats done it before. I guess I'll have to source drum carriers and hubs and then just make an adapter plate to hold the calipers.
40inches
posted on 27/9/19 at 09:45 AM Reply With Quote
Adaptor plates are available, MK sell them for one.
If you want to make your own, I have a pair that I could trace onto card for you
falcor75
posted on 27/9/19 at 01:54 PM Reply With Quote
Thank you for offering but I've got access to lasercutters at work so the adaptor plates is the easy part to fix.
falcor75
posted on 30/9/19 at 05:13 AM Reply With Quote
Picked up an entire Sierra rear axle last night for £40.
