Author: Subject: Dual master cylinders and balance bar VS tandem and portion value
woodsy144
posted on 10/12/19 at 08:41 AM Reply With Quote
Hello, as subject suggests is there any advantage / disadvantage of one over the other. Based on space and weight I am thinking of designing a box using the later, but want to fully understand the systems.
JonBowden
posted on 10/12/19 at 10:14 AM Reply With Quote
If you use dual master cylinders with a balance bar, you will be able to adjust the balance to get it just right but with a single split master cylinder, you may need to play with the size of the wheel cylinders.
I believe that for IVA, you must either use a single split master cylinder or if you have dual ones, the adjusting mechanism must be welded up to prevent adjustment.
Jon
JAG
posted on 10/12/19 at 08:02 PM Reply With Quote
I would suggest you choose a third option...
3) Tandem Master Cylinder and adjust the brake sizes to get the correct front:rear balance.
Proportioning valves are an unnecessary complication and a twin master cylinder and balance bar arrangement has to be welded in one setting for IVA.
My car has M16 front calipers from a Cortina and the 8" drumbrake from a Ford Escort. I increased the drumbrake wheelcylinder size from 19.05 to 20.64 mm diameter to adjust the front:rear balance.
Justin
woodsy144
posted on 10/12/19 at 08:06 PM Reply With Quote
In Au, we don't have to weld balance bar. Just make it so the driver can not adjust it, ie remove the adjustment knob and cable. (and reinstall later.... Cough cough)
Oddified
posted on 10/12/19 at 08:56 PM Reply With Quote
The other way is use a dual master cylinder and then change pads front or back with differing coefficient of friction, works very well.
Ian
voucht
Contributor
Posts 246
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 11/12/19 at 06:52 AM Reply With Quote
They are two different kinds of systems, and it have different purposes. It is a bit like comparing pears and apples.
On the first (balance bar), you just push more on one master-cylinder and less on the other one, and you chose how much you push on each one by adjusting the balance bar. But you don't put any limitation on the brake circuit. Mechanically, it makes much more sense. It can be used to finely adjust your front/rear brake balance permanently. But is will be the most expensive setup of the two.
The second one (proportioning valve) is a limitation on the pressure of the rear brakes. The force applied to the master cylinder is the same, there is just a restriction on the "downstream". Do not forget that most of the proportioning valves do not limit the rear brake more than 57%, and it might just not be enough anyway if your front/rear brake system has been poorly planned. Normally, this system is used only when one master cylinder (tandem) must be used (road or racing regulations). For example on rally cars, in series where dual master cylinder setup is not allowed, it is used to adjust the rear brake between dry road and wet road conditions. But it is not designed to be used to balance your front/rear permanently. Plus it is more connections on your brake circuit, which is more chance of leaks, bubbles, bleeding issues, etc. But it will be the cheaper setup of the two.
As said above, the first thing is to correctly design you brake system and chose the right size of front/rear callipers to get the best front/rear brake balance possible.
If you need to adjust, and money is not the biggest issue, I would suggest that you go for the dual master cylinder + balance bar, as it is allowed in your country.
https://vouchtroadster.blogspot.com/
https://caferacer-kawa-gpz-zx550.blogspot.com/
