axle
| posted on 16/12/19 at 03:36 PM |
pluming the T7 heater
Hi All
At long last I managed to buy a T7 hear thank you all for your advise .
As the bore diameter for hose from the engine is 16 mm and the heater is 13 mm not sure if I should use a reducer or make up the difference with a
small piece of 13 mm hose may be the latter method is not very safe!
Please tell me what you think or how you did it with your T7 heater?
Regards Axle
IVA passed 1st time thanks to the Forum members.
| posted on 16/12/19 at 04:41 PM |
Not used one myself, but I'd plumb it with a reducer. I'd feel it was done properly that way and less likely to leak.
lsdweb
| posted on 16/12/19 at 06:09 PM |
I used a reducing bulkhead connector - https://www.t7design.co.uk/bulkhead-hose-adapter-1-2-5-8-narrow.html
axle
| posted on 16/12/19 at 07:51 PM |
Thanks for your response I certainly will not use the latter method, the T7 design looks really good but out of stock not sure how long I will have
wait,
Thanks again
Regards Axle
40inches
| posted on 16/12/19 at 11:28 PM |
wait,
Thanks again
CBS do something similar https://www.carbuilder.com/uk/bulkhead-reducing-heater-hose-joiners-16mm-to-12mm
axle
| posted on 17/12/19 at 10:38 AM |
It looks like it is going to be CBS as the other one is out of stock. Thanks for all your replies
Regards Axle
40inches
| posted on 17/12/19 at 11:31 AM |
Demon Tweaks do the ally one Link
axle
| posted on 17/12/19 at 02:32 PM |
Thanks again do you think alloy one is better I was going for the CBS one because it will cover the existing hole, however if it means alloy one is
better in the long term that is what it will be?
Regards Axle
Bluemoon
| posted on 17/12/19 at 03:00 PM |
I would go for plastic, will not corrode..
axle
| posted on 17/12/19 at 07:23 PM |
yes I see your point, TBH that is more suitable for me, but would the plastic not eventually become brittle and crack?
Regards Axle
Bluemoon
| posted on 17/12/19 at 08:50 PM |
Depends on the quality! If OEM quality I would be happy.
