skidmark71
| posted on 1/5/20 at 06:42 AM |
7" Sierra Diff mounting bolts.
Does anybody know the thread size of the 2 bolts for the rear diff mount onto the diff cover. Thanks.
Myke 2463
| posted on 1/5/20 at 09:05 AM |
M 10 on mine.
Be Lucky Mike.
jacko
| posted on 1/5/20 at 04:03 PM |
M12
I must learn to read the hole question
It is 10mm for the rear cover not 12 as I put first
The two bolts are 12mm holding the dif to the chassis
Jacko
[Edited on 1/5/20 by jacko]
skidmark71
| posted on 2/5/20 at 08:05 AM |
Thanks for the replys guys. Much appreciated. I have already tried M10 and although it starts and screws in about one turn it starts to bind up and is
at a slight angle. It's not bottoming out and the threads are clean and undamaged. I don't want to force it just in case I crack the
cover.
Im thinking it may be an imperial thread? 3/8 UNC or UNF. I've ordered a couple of these to give them a go. Will let you know how I get on.
| posted on 2/5/20 at 09:54 AM |
What pitch have you tried? There are at least 3 different pitches for 10 mm threads.
jacko
| posted on 2/5/20 at 04:06 PM |
Defo 10mm
