FuryRebuild
| posted on 19/8/20 at 07:44 AM |
Fury IRS drive shaft boot needed
Hi All
Does anyone know which drive-shaft boots belong on the Fury Original IRS (with the sierra diff). My drive shafts are splined both ends. I think they
were cosworth sierra spec originally.
Many thanks
M
www.furyrebuild.co.uk
mcerd1
| posted on 23/8/20 at 07:38 PM |
Cossie 2wd shafts have 108mm lobro CV joints
Cossie 4x4 shafts have 100mm lobro's
Std GKN boots should be all you need, but if it's a tight squeeze you can get 'fast boots' (lots of car brand use these
joints/boots)
https://www.demon-tweeks.com/uk/gkn-standard-cv-joint-boot-117139/
Or:
https://www.demon-tweeks.com/uk/gkn-aerodynamic-cv-joint-boot-243477/
If it's not one of the above then it'll just be a std. Sierra one rather than a cossie
