Author: Subject: Wheel spacers
number-1
posted on 1/9/20 at 06:01 PM Reply With Quote
Wheel spacers
Can anyone point me in the right direction for a pair of 10 or 15mm hub centric wheel spacers for my car. 4x108 so ford fitment and a centre bore of 63.4
Ive got some of these but am not happy about them not being hub centric as its just the 4 wheel bolts taking the weight of the car etc
N1
ian locostzx9rc2
posted on 1/9/20 at 08:33 PM Reply With Quote
Normally available via e bay 15mm are available may struggle with 10mm probably to thin to be hub centric
[Edited on 2/9/20 by ian locostzx9rc2]
MikeR
posted on 2/9/20 at 07:19 AM Reply With Quote
I've been looking for 10mm hub centric and struggling. Seems it's too thin. Plenty of 20mm on eBay or Amazon etc. If you find some let me know
Schrodinger
posted on 2/9/20 at 07:51 AM Reply With Quote
If you have spigots in your wheels to make them fit on you hubs you may be able to take them out and get some made but if not I dont think you will find any . If you do find any they will be like tissue paper at the wheel.
Keith
Aviemore
mcerd1
posted on 2/9/20 at 09:16 AM Reply With Quote
thats what I found - you can get 15mm thick - but even that would leave very little metal - especially since they undercut these in the corner normally
I made my own 15thk ones (granada 5x112 pattern) in order to take advantage of the chamfer on the wheel etc and gain back some of that metal
on mine the hub spigot sticks out 11mm past the disc (so 4mm left for a 15thk spacer + clearances)
In the end I went with stainless centre parts and anodised alloy spacers
Spacers for rear wheels
(photo's are still acting up )
I've also got a drawing for 1 part 30mm thick ones based on mine.
if you want CAD files / drawings for these (or a similar version) drop me a u2u
[Edited on 2/9/2020 by mcerd1]
mcerd1
posted on 2/9/20 at 09:36 AM Reply With Quote
depends what wheels they are...
my borbet wheels have fairly thick plastic rings snapped into them - when you order the wheels they drill the PDC, but the centre bore is machined to a standard size and they supply the spigot rings to suit your hubs.
This is fairly common for aftermarket wheels.
if your wheels are like that you could always remove the rings (or get larger ones, say merc at 66.6mm or BMW at 74.1mm) then you got a bit of metal to play with - but that would need you to get custom spacers made 63.4mm inside to the larger outside... and your wheels would need to be different front to back (unless you got spacer rings at the front too)
it could be a good way to do it - but its not without some compromise and won't suit everyone
Schrodinger
posted on 2/9/20 at 10:35 AM Reply With Quote
That is what I was trying to say, I made some from ally for my Tiger with TSW wheels and took the rings out of the wheels to give some meat on the spigot.
Keith
Aviemore
number-1
posted on 2/9/20 at 12:52 PM Reply With Quote
Cheers for the replies chaps
Ive got Borbet wheels on the car now and they come with black spigot rings inside the wheel bore as like mcerd1 mentioned in his reply.
Its just the rears i need to space out. I really only need 5mm but if i add them to the hub, it doesnt leave any of the hub flange (not too sure what its actually called) sticking out to allow the CB of the wheel to sit on. The 5mm spacers dont have then flange on them.
Im not too sure how safe it is to only have the wheel bolts taking the weight/power of the car?
N1
mcerd1
posted on 2/9/20 at 01:17 PM Reply With Quote
Originally posted by number-1
Ive got Borbet wheels on the car now...
Nice choice
what ones have you got ?
Its normally called a spigot (at least in the UK)
I assume this is an escort axle ?
I don't have one handy to measure, but if you can check a few sizes I could easily make you up a drawing / cad file for a custom spacer
I have a man locally that can make them too (my old lathe is too knackered to do these acutely enough) but thats probably a bit far away from you
Actually none of the weight should be on the spigot or the bolts directly - the wheel is clamped hard to the hub and all the load is transferred by friction (which is actually very high due the clamping force) - thats why its important to torque your wheel nuts
its similar to how most steel bridges are bolted together using HSFG fastners (high strength friction grip) - most are designed so that all the load is take by the friction between the parts and no shear load is ever placed on the bolts.
if you go back in time a bit all wheels were centred on the studs/bolts (aka what the US would call 'Lug centric' rather then the modern 'Hub centric' )
The only real issue with this is that its not as accurate and could give some unwanted vibration at the wheels (hence the reason cars changed to hub centric designs as speeds increased
number-1
posted on 2/9/20 at 01:38 PM Reply With Quote
Ive got these ones but had them powder coated black.
mcerd1
posted on 2/9/20 at 02:16 PM Reply With Quote
Those wheels were out about the same time as mine: (so I assume they have similar design of rings etc..)
Rear Wheel
Rear Wheel
looks like you can get the spacer rings still (assuming they are the right size ones)
https://www.borbet.de/en/products/webshop-detail.php?relid=14
