Author: Subject: Which car for Fuel Pump
mad4x4
posted on 30/1/05 at 11:52 AM Reply With Quote
Can anyone tell me vehicles that would have an electric fuel pump instead of a mechnical one?
need about 4psi at 100+ liters per hour
The last time I looked a lot of cars have "intank" pumps - this is not suitable for my application
Scot's do it better in Kilts.
mandy69
posted on 30/1/05 at 12:24 PM Reply With Quote
Landrover, Moggy or just buy a facet one
Jon Ison
posted on 30/1/05 at 02:51 PM Reply With Quote
if you can find a jag in a scrappy they have a nice one, infact two.
posted on 30/1/05 at 04:01 PM Reply With Quote
The original Rover 216s (SU carb) the old 80s 3 box type have a nice silent AC pump mounted underneath the car just ahead of the ns rear wheel.
DarrenW
posted on 2/2/05 at 02:12 PM Reply With Quote
VW golfs (mk1 and early mk2's) and Audi 80's have the bosch type underneath just in front of the o/s rear wheel. (Sometimes covered by a big noise dampaning tube thing).
omega 24 v6
posted on 2/2/05 at 05:29 PM Reply With Quote
2 LTR carltons circa 91 had electric stand alone pumps at rear of axle.They also are in a big foam tubey noise dampener type thingymabob (yes this is the tech phrase for it)
[Edited on 2/2/05 by omega 24 v6]
tomm
posted on 21/2/05 at 05:44 AM Reply With Quote
what about the mini! remember the one in the boot! SU i think? cheap tooooo!!
Snuggs
posted on 21/2/05 at 07:44 AM Reply With Quote
Check this site for Facet pumps.
http://www.trackstore.co.uk/shop%20frame.html
[Edited on 21/2/05 by Snuggs]
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
posted on 21/2/05 at 10:04 AM Reply With Quote
No, I always remember it being under the boot in the subframe, covered in SH!TE and corroded to F%c& with no chance of fixing it in the middle of winter 10 miles from home
NigeEss
posted on 21/2/05 at 04:58 PM Reply With Quote
Early V8 Range Rovers and V8 Land Rovers have a high capacity SU type low pressure elecky pump.
paulbeyer
posted on 22/2/05 at 12:15 AM Reply With Quote
BMW 3 series rubber tube covered Bosch jobbie same as VW Audi Kraut wagens. Cheap too.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Bart69
posted on 22/2/05 at 06:05 PM Reply With Quote
My Sierra 2.0i gls had a pump strapped under the tank had to change it and got the same one from an Audi 80 i think.
hope that helps
tomm
posted on 26/2/05 at 04:11 PM Reply With Quote
peterf hey you are dead right it is undeer the floor on the mini and yes I remember it all covered in shite!! must be my age I'm forgetting all the little details, remember the new one was cheeep though!
paulf
posted on 27/2/05 at 08:28 PM Reply With Quote
I remember my MG being like that ,luckily it had wire wheels and a good clonk on the pump with the knock on mallet always got it going again .
Paul.
owelly
posted on 13/5/05 at 09:55 PM Reply With Quote
Are we talking lift/supply pumps or injection system pumps??
If you plop a high pressure pump from an injection car, to feed carbortooters, it will blow them to bits. Likewise , if you use a low pressure (ie Mini, Moggy, any carb car...) to squirt at a set of injectors, you'll not break many speed records.
And don't forget to check part numbers for injection system pumps. I recall fitting a Pierberg/Bosch type pump to my SD1 Vitesse and it would only tick over. The pump I fitted looked identical but it was from a Vauxhall Cauliflower SRi and one digit was wrong on the part number so the flow rate/pressure was wrong.
Just a thought or two.....
http://www.ppcmag.co.uk
NS Dev
posted on 15/5/05 at 09:11 AM Reply With Quote
A couple of comments, several of the pumps mentioned here are injection ones so no good for your 4 psi requirement!
I would say the best source is a Facet, taken from a carburettored Range Rover. These actually use the same Facet pump that you can buy from a motorsport supplier, but at breakers yard prices. It's located under the floor on the passenger side (I think?) under the "step" in the floor that the seats are mounted on.
