Author: Subject: ZZR1400 clutch cylinder bore size ?
Erazor
posted on 29/5/21 at 08:29 PM Reply With Quote
Hi Guys,
First post. I have put a Kawa ZZR 1400 engine in my Bond Bug and need to connect the clutch. How do I get the correct size of reservoir, bore wise to suit the Kawa. What did you guys fit in a kit car with a Kawa engine or other bike engines that are hydraulic ??
Any advice would be great.
adithorp
posted on 29/5/21 at 09:12 PM Reply With Quote
I think folks commonly use the bike rear brake master cylinder. Think it might be 13mm. If you're looking for car master then 1/2". I've seen a couple with 5/8" master on BUSA motors and they've needed a pedal stop fitting to prevent overthrow of the slave.
http://jpsc.org.uk/forum/
snapper
posted on 29/5/21 at 10:26 PM Reply With Quote
First post, stunning project.
With a 3 wheel car your compromised on braking due to 1 wheel but you know that, bias pedal box would give some much needed adjustment.
I eat to survive
I drink to forget
Erazor
posted on 30/5/21 at 08:32 AM Reply With Quote
Just looked up bias boxes, thanks for info
russbost
posted on 31/5/21 at 01:16 PM Reply With Quote
Hi, I think i've spoken with you on Pistonheads B4, unless there are 2 of these!
use the ZZR1100 master cylinder with the ZZR1400, old ZX10 is also identical, may be the same as ZX9R, but unsure of that - there is a reason which escapes me why using the ZZR1400 clutch master isn't great - IIRC it may be the way it's integrated into the handlebar lever & housing
Oli at Furoreproducts can make up any braided hoses you need
Erazor
posted on 1/6/21 at 09:26 AM Reply With Quote
Looks like I have found what I need. Balancing bar will work well with rear discs and front drum and have different bore sizes on the master cylinders.
The pedal boxes also have an adjustable clutch stop which prevents over stroking.
r1_pete
posted on 3/6/21 at 04:23 PM Reply With Quote
Perhaps because the zzr1400 master cylinder sits at 90 degrees to the bars, rather than parallel??
