nickm
| posted on 24/9/22 at 04:18 PM |
Hi Torq Starter or Battery
Afternoon Folks
Fitted some phase 2 road cams to a 1.6 zetec se with Jenvey 42mm dth tbs in the spring and now i have an intermittent starting problem.
Mostly happens when the engine is warm i am assuming its raised the compression slightly and the starter/battery is not man enough to turn it over
What do people think starter or battery or both
The car runs like a dream though, it pulls like a train after it was r roaded 144hp tune (it made 148 max but has a sensible road map) and a flat line
of torque between 2500-6000rpm of 127-129.
Nick M
theconrodkid
| posted on 24/9/22 at 04:32 PM |
first things to check would be is the battery, right size, any good and fully charged, loose / dirty cable conexions esp the earth. then , how close
is the starter to the exhaust, heat can cause them problems
who cares who wins
pass the pork pies
gremlin1234
| posted on 24/9/22 at 07:45 PM |
one test you could do. have a jump starter along with the current battery to see if it really goes wizz.
but do check the cables and 'earths' before anything.
nickm
| posted on 26/9/22 at 06:28 PM |
Pretty sure all connections are fine will have to look at CCA and possibly uprate the battery power as a first resort.
Nick M
coyoteboy
| posted on 29/9/22 at 02:46 PM |
Does it sound like it turns over slowly? What is the ECU/Fuel/Spark control system? Could it be something as simple as being below a cranking
threshold on an ECU? Normally warm cranking is easier.
https://www.fixmystreet.com/
nickm
| posted on 29/9/22 at 06:15 PM |
Hi
The ecu is emerald and it has been rolling roaded.
Pretty sure it is lack of grunt fm either batt or starter when it wont go there is nothing no cranking whatsoever when it does start you can hear that
the batt/starter is finding it harder work than prior to the cam change you wouldnt think 0.1mm extra of steel lobe would make that difference !
First will be to up the CCA and see what i get
Nick M
gremlin1234
| posted on 29/9/22 at 06:50 PM |
as Coyotboy asks, what is the mode of failure?
does the engine turn about a quarter to half turn, then just stop?
if so... I suspect the engine is firing before tdc, and then stalling the starter.
coyoteboy
| posted on 30/9/22 at 11:42 AM |
quote: Originally posted by nickm
Hi
Nick M
Nah you have a bigger issue than just increased compression, if it isn't turning over at all you either have a duff battery or really dodgy
connections (including all contactor points through the system such as any of those in a starter. Your starter shouldn't struggle to reach
2-300rpm.
SJ
| posted on 30/9/22 at 12:08 PM |
My Zetec BT did this on the standard starter when hot. A new geared starter fixed it for £60. Zero problems since
Kdempsie
| posted on 8/11/22 at 02:28 PM |
I have a Sylva J15 and had had the same problems you describe on my earlier Sylva Mojo. I bought a hi-torque starter for my J15 to solve it, the
battery is fairly big and all cables short and big diameter / capacity.
It didn't solve the issue! My problem is the starter getting too hot because there is not enough engine compartment cooling and a lot of hot air
blasted up the tunnel.
My symptoms are that it won't turn over at all, until it cools a bit. It cools pretty quickly, especially if I open the engine lid.
I intend to stop the hot air blast up the tunnel but it only happens when it's hot days and hard(ish) driving so I haven't made it a
priority.
Keith.
nickm
| posted on 8/11/22 at 08:07 PM |
Thanks Keith
Think it was a faulty alternator in the end but have had limited running since changing it, that was also not helping in charging the battery i hate
car electrics i can make it all work though without fully understanding it !
Even after fitting the alternator i cant understand why the circuit diagram shows it being earthed to the engine but its secured to the head and block
by 3 steel M10 mounting bolts !! but its started everytime and is charging the batt at 13.7v
Ta
Nick M
