phil m
| posted on 24/10/02 at 09:27 PM |
Master cylinder-overhaul
sorted out the Cortina re-con calipers, now looking at the master cylinder . Not using a servo - what do you suggest for availability to overhaul or
re-con .
Escort MKII -seals/re-con not found and new one £72 -
What to do ?
Thanks , Phil
| posted on 25/10/02 at 07:42 AM |
I used an Escort one - just needed an overhaul kit to make it good.
You can get repair kits for just about any common master cylinder. The only thing that can't be fixed is rusted or worn bores - then it's uneconomic
to repair.
theconrodkid
| posted on 25/10/02 at 05:04 PM |
throw the master in the bin if it need reconing,i wouldnt re seal them,try escort 3/4 masters,similar and a lot cheaper.
James
| posted on 25/10/02 at 05:41 PM |
to repair.
You could of course do what my Dad did with his old Anglia many many years ago which now makes him cringe when he remembers what he did:
Make a small roll out of emery paper and rub down the inside of the bore with that!!!
James
