posted on 21/7/24 at 06:17 PM |
Different types of maxi ball joint
Whilst I'm asking for info, may as well add this. There seems to be two types of maxi ball joint for front lower. The one with a bolt either
side, and the one that screws into a large thread in the wishbone. Are the both from Austin Maxis? What's the difference? Model? Age? Any reason
against using the threaded one? How does it stay in?
Cheers!
jacko
posted on 21/7/24 at 08:29 PM |
From what I can find the maxi ball joint two bolt is for a maxi 1969 - 1975 part no
Qsj602
The other is maxi , allegro, princess , ambassador 3 liter
And maybe morris 1500 nomad
This one is not tapered like the two bolt.
Graham
I found this on google image.
I maybe wrong but it looks like a bolt goes through the ball joint and the bottom arm
[Edited on 21/7/24 by jacko]
555
posted on 21/7/24 at 09:04 PM |
Thanks Jacko. Interesting if it's not tapered! Might have to take it all apart and see.
posted on 22/7/24 at 11:48 AM |
The Sierra based MK Indy I built used the 2 bolt Maxi ball joints. I think I may even have got them from MK when I got the chassis, wishbones etc.
From memory MK had to ream the lower holes of the Sierra uprights to suit the taper of the Maxi joints.
posted on 27/7/24 at 05:37 PM |
If you look on ebay for maxi ball joints, they're nearly all 2 bolt ones. The only ones that look like mine are described as metro ball joints,
like this -
https://www.ebay.co.uk/itm/124799203266?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=oGZqJ5s-SYK&sssrc=4429486&ssuid=yQErn8OURaO
&var=&widget_ver=artemis&media=COPY
Be interested to know if that part is really not tapered though. Kinda makes sense, much easier to drill a straight hole than a taper!
Might order a pair to find out before I actually need them!
