<<  1    2  >>
Author: Subject: EXHAUST IN TUNNEL?
quattromike
posted on 10/2/05 at 08:40 AM Reply With Quote
EXHAUST IN TUNNEL?
Hi all
I'm building my chassis right now and have made my tunnel nice an wide , 210mm inside to be exact and planned to run my exaust through it and out the back instead of out the side like normal locosts. Does anyone know of any reasons why that might not be ok for the SVA before i go too far?
I mean most normal cars have the exhaust through the tunnel and out the back right! so it must be ok
shortie
posted on 10/2/05 at 08:45 AM Reply With Quote
Although it's wide will it fit with the prop in there aswell??
You would need some serious heat protection and also it would be close to the fuel and brake lines and wiring.
I'm not sure it would be looked upon that well at SVA.
Rich.
posted on 10/2/05 at 08:46 AM Reply With Quote
Are you going to have the bottom of the tunnel open? If it will be closed then the heat build-up could be impressive! Most production cars run their exhausts along grooves in the floor, open to the air.
Standard disclaimer: these views are purely conjecture and not based on personal experience...
Mind you - my exhaust get bleeding 'ot after a run - you can feed the radiated heat a few feet away.
[Edited on 10/2/05 by David Jenkins]
quattromike
posted on 10/2/05 at 08:53 AM Reply With Quote
yes,
The tunnel is open to the world at the bottom and also the exhaust is planned to sit half in and half out the bottom of the chassis this is because it has to go below the gearbox mount which sits about 2" up from the botom of the chassis.
Cheers Mike.
[Edited on 10/2/05 by quattromike]
smart51
posted on 10/2/05 at 12:07 PM Reply With Quote
the Dodge Viper exhaust gets so hot it glows red. They have very expensive sils to box it in without melting. Enclosed exhausts are much better IMO. I'd rather have one myself, but be careful how you do it.
jollygreengiant
posted on 10/2/05 at 12:15 PM Reply With Quote
Most main exhaust pipes (excluding cat & associated down pipes Which tend to be stainless and run about 200 degrees hotter) tend to run, in open air, at just below visible red temperature, which I beleive is about the 600 degree mark, when an engine is on full song at motor way speeds. This is why it is possible to wrap a steak in foil and cook it by securing it to your exhaust , then going for a long drive.
For these reason it is not a good Idea to place the exhaust IN the tunnel.
posted on 10/2/05 at 12:31 PM Reply With Quote
Unless you have a vented top on the tunnel with hinges and a clip fastening system you will not be able to tell when your steak is done, so it's not a good idea.
Alan_Thomas
posted on 10/2/05 at 05:33 PM Reply With Quote
It wouldn't matter how well you insulated it I guarentee that it you went fo a 'sprited' drive then got out and left it a few minutes you would leave the skin of your hand on the tunnel when you got back in it. The heat would soak up into the structure when left and you arm, hand, thigh frequently touchs the tunnel when driving and getting in or out
- Alan
quattromike
posted on 10/2/05 at 05:35 PM Reply With Quote
I meant it would come along just under the tunnel and not in it as such , but surely most modern cars have the exhaust along underneath the car so it can't be that bad?
I will have to have heat sheilding in places, like where it passes the petrol tank.
Mike.
NS Dev
posted on 10/2/05 at 05:46 PM Reply With Quote
I wouldn't do it.
I have dealt a bit with GT racing cars with enclosed and semi-enclosed exhausts and they are a complete pain in the ar5e!
For one, it will make tunnel acces more difficult than it already is on a seven, and for that reason alone i wouldn't do it, but it will also get very hot, as has been said, and may be likely to cook the grease in the front UJ of the prop, depending on how close it is to the exhaust.
mangogrooveworkshop
posted on 10/2/05 at 06:21 PM Reply With Quote
I would rather have space in the cockpit than wasted on the tunnel
Smooth Torquer
posted on 10/2/05 at 06:32 PM Reply With Quote
Don't Westfield run the exhausts on some of their V8 powered cars down the tunnel?
Sam
carnut
posted on 10/2/05 at 06:43 PM Reply With Quote
I like the idea of exhaust enclosed from the aero point of view. Would be nice to duct a bit of air down the tunel to keep things cool and use some exhaust wrap in places where you dont want heat or maybe whole length.
DarrenW
posted on 11/2/05 at 09:40 AM Reply With Quote
Personally i like the idea. Only reservation is that the cars are small and space is tight.
On my car ive put the floor straight across the bottom of the tunnel. An idea for central exhaust may be to recess the central part of the floor into the lower tunnel area by approx 70mm thereby creating an open bottomed exhaust tunnel (ie std tunnel is split into two with false floor - exhaust below, prop above). The prop could then go above this new floor section in the standard tunnel.
Inside the exhaust tunnel heat proof reflective material could line it and protect prop from drying out and excessive heat into cockpit.
Tricky areas - getting the exhaust to go from manifold to the underneath of tunnel without being to low.
Access to gearbox etc for oil changing / clutch changing.
Exhaust routing thro back under diff / fuel tank.
What about creating a shallow exhaust tunnel in the passenger footwell floor. If it is no higher than std seat runners it should result in the pass seat being much higher than normal. Instant seat warmer!
Alternatively modify the side of the chassis and make the box run up the inside of the 'sill' area. This way it will be just inboard of the normal external position. Rear routing will need to be carefully thought out tho'.
posted on 11/2/05 at 10:13 AM Reply With Quote
I must admit that I like the idea as well - I worry about people coming into contact with the exposed hot pipework after a run.
[Edited on 11/2/05 by David Jenkins]
quattromike
posted on 12/2/05 at 12:10 PM Reply With Quote
Well i think it's fair to say there's been a bit of a mixed reaction on this subject but this only encourages me even more to do it. I've commited to it now so i will carry on and prey that it'll be a sucsess .
Mike.
P.S. cheers for all responsess so far .
wilkingj
posted on 12/2/05 at 11:51 PM Reply With Quote
Bring the exhaust outlet out to one side, as if its directly behind the car, the exhaust fumes will be swept up in the turbulence and swirl around the area of your head. Which is not the best you can do for your health.
OK, it wont be that bad, but it could be.
Its not the best idea.. I did this on my Landrover, and it filled the vehicle with fumes. Bring it out at the side..
Best Regards
Geoff
http://www.v8viento.co.uk
quattromike
posted on 13/2/05 at 03:16 AM Reply With Quote
The plan was to take it right down the middle then split it behind the diff and have two back boxes out from the middle to each side and out and mabey have the back boxes low enough so you can see them from behind to add a bit of bling . or it was suggested that from the 4-2-1 manifold just have the 4-2 part and take a smaller pipe down each side of the tunnel and then out along the back again, but i'm not sure about that idea because i'm not sure what it's gonna do for my engine power / torque.
cherrs Mike.
NS Dev
posted on 13/2/05 at 09:52 AM Reply With Quote
you are right, it won't help the engine performance doing that with the 4-2-1.
You just need to bear in mind the heat output of the pipes. On a leading manufacturers GT car, the heat was severe enough to burn the paint off anywhere near the exhaust, and melt the insulation off wiring a 1.5 feet away from the tunnel!
Having said that, most road cars dont suffer from that problem, but they are not operated at such high powers for so long, and have a less enclosed tunnel.
posted on 13/2/05 at 11:29 AM Reply With Quote
I've seen a Rover 800 burnt out becase the cat was mising its heat shield and the sound proofing in the interior started to burn . The air going through the tunnel is already pretty hot without adding to it.
quattromike
posted on 2/3/05 at 09:16 PM Reply With Quote
This is what i had i mind:- Rescued attachment TUNNEL.jpg
Mark Allanson
posted on 2/3/05 at 09:24 PM Reply With Quote
Take a look at the underside of your quattro, and see the exhaust heat shields, particularly at the opening of the tunnel. A bit of curved ally isnt going to be upto the job
quattromike
posted on 3/3/05 at 10:39 PM Reply With Quote
I agree with what your saying ,so do you think if i added some heatproof material to the cover will it help ? Rescued attachment TUNNEL2.jpg
Mark Allanson
posted on 4/3/05 at 09:05 PM Reply With Quote
I cannot see how you can fit the exhaust, heat shield and the other gubbins into such a small space, I struggled with just the prop, fuel pipes, wiring etc Rescued attachment Tunnel Clearance Exhaust.jpg
Simon
posted on 5/3/05 at 01:38 AM Reply With Quote
Mike,
From your photo archive it looks you're going IRS of some description (w/bones or de dion).
Bear in mind your ex pipe will need to go round diff, fuel tank, w/bones (or de dion tube) and any other gubbins that may need to be in there (battery perhaps?).
I like the idea, but think you'll find it far too much aggro. Don't forget, you'll also have to get it into tunnel and front end too! With a dirty great b/housing in the way.
You may be better going for something like 3 or 4" x 1" box tube and running it under car.
As for comments about the Viper, Top Gear managed to set the exhaust "tunnel" alight. And that's a major motor manufacturer.
Good luck
Simon
<<  1    2  >>
