<<  1    2  >>
Author: Subject: monoshock - why, whats the advantage?
MikeR
posted on 18/2/05 at 12:39 PM Reply With Quote
Guys,
Just seen some pics of a mono shock from the GTS challenger....
I'm curious, why use a mono shock? Whats the advantage? whats the effects with regard to handling? How does it affect the shock? Why has no one else done it on a IRS seven? Why not use it in the front instead of twin shocks?
chrisf
posted on 18/2/05 at 01:35 PM Reply With Quote
It seems to me that the mono shock has built in anti roll. Another advantage is that it can easily be designed as rising rate. It also has weight advantages.
I too am interested in how it drives--specifically how it behaves in roll and extreme bumps.
--Chris
JonBowden
posted on 18/2/05 at 03:05 PM Reply With Quote
Can anyone give a more detailed explanation. I just don't get this monoshock idea.
If my (poor) diagram is about right, then the spring / damper unit should resist bump that affects both wheels at the same time (eg speed bump or squat due to acceleration).
It should provide absolutely no roll resistance at all.
I think that this should give good grip at the rear and possible understeer as the front is providing all the roll resistance.
[Edited on 18/2/05 by JonBowden] Rescued attachment Monoshock.gif
Jon
Alan B
posted on 18/2/05 at 03:17 PM Reply With Quote
Jon, I asked this question myself on another thread.
Where does the roll resistance come from as none is apparent from pictures?
Edit:
This thread....
http://www.locostbuilders.co.uk/viewthread.php?tid=19793
[Edited on 18/2/05 by Alan B]
NS Dev
posted on 18/2/05 at 03:35 PM Reply With Quote
there are a large number of ways of doing a monoshock, some useful and have point, others less so with little point other than the "because I could" value!
A Trishock arrangement with two normal pushrod operated shocks plus a third for antiroll is a more interesting arrangement, as it gives very tuneable roll characteristics, but adds weight.
The system that I can not fathom out is the Dax antiroll system, which seems to be completely solid in roll but also when 1 wheel moves separate to the other (over a bump and not in roll!)
JonBowden
posted on 18/2/05 at 03:36 PM Reply With Quote
Alan,
I read your previous post. Even without an anti-roll bar, normal suspension resists roll. This design does not do that. As far as I can see, if this setup was used at both ends, the car could be pushed over with one finger. Or am I missing something - some F1 cars use a single spring / damper
Jon
Alan B
posted on 18/2/05 at 03:43 PM Reply With Quote
Jon, exactly my point....this set-up with the single spring not anchored to the chassis anywhere can move freely in a roll situation....it needs an anti roll bar or some means of resisting roll.....
I understand the dual roles of bump and roll resistance in a conventional set-up and that an anti-roll bar is not always required.
NS Dev...
Yep, I've seen the arrangements you describe....all provide some roll resistance.
The question here is what provides roll resistance in THIS set-up rather than how it is usually done.
Piledhigher
posted on 18/2/05 at 05:06 PM Reply With Quote
Based on the diagram above, it looks like the shock is tied to the frame through the pivots. When there is body roll would not the shock/spring combo resist roll based on the spring characteristics?
Cory
NS Dev
posted on 18/2/05 at 05:39 PM Reply With Quote
NS Dev...
yes, see what you mean...........nothing as far as I can see!
chunkielad
posted on 18/2/05 at 05:40 PM Reply With Quote
Alternative setup used in Formula Renault
[Edited on 18/2/05 by chunkielad]
JonBowden
posted on 18/2/05 at 05:46 PM Reply With Quote
found this diagram and description for a swing-axle suspension with a similar transverse mono-shock in formula Vee
http://www.fvee.org.au/handbook/rearsusp.html
They say there is no roll resistance
Jon
NS Dev
posted on 18/2/05 at 05:47 PM Reply With Quote
....................and best left on a formula renault I think!
not much use if it goes over a bump!
MikeR
posted on 18/2/05 at 05:59 PM Reply With Quote
damn, i was looking for a more positive view as it would fit nicely over my brand new (well new to me) audi transaxle....
looks like two shocks next to each other pivoting against the chassis would be better.
gazza285
posted on 18/2/05 at 06:03 PM Reply With Quote
Works on a single seater as the roll resistance comes from the rear and race tracks are generally smooth.
chrisf
posted on 18/2/05 at 06:12 PM Reply With Quote
Gents:
Understand that I offered my understanding of the system. By no means was I trying to proclaim and absolute truth. As it turns out, I am wrong. I'm still interested in how it drives.
--Many apologies for the propaganda, Chris
MikeR
posted on 18/2/05 at 06:15 PM Reply With Quote
Chris all propaganda is welcome, as long as the truth is found in the end! )
(disclaimer - I am not responsible for any blood letting in the finding of the truth!)
CD-5
posted on 18/2/05 at 06:35 PM Reply With Quote
This look more logical for a mono shock setup. taken from the drysdale motorcycle site.
[img]http://home.mira.net/~iwd/openwheeler/dh-7.htm[/img]
NS Dev
posted on 18/2/05 at 08:04 PM Reply With Quote
oh dear Mike!! Hadn't you better finish this one first!!!???
MikeR
posted on 18/2/05 at 08:29 PM Reply With Quote
off this week to push that along!
NS Dev
posted on 18/2/05 at 08:55 PM Reply With Quote
you don't want to push it, you need an engine!!!
niceperson709
posted on 18/2/05 at 09:42 PM Reply With Quote
I saw a set up like this on a 2F 1R trike he claimed it does work .
photo below , a wild machine by the way
best wishes
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
niceperson709
posted on 18/2/05 at 09:44 PM Reply With Quote
and here is a discription of how it works from "Motorcycle sport" magazine
best wishes
Iain
Best wishes IAIN
niceperson709
posted on 18/2/05 at 09:47 PM Reply With Quote
Best wishes IAIN
niceperson709
posted on 18/2/05 at 09:49 PM Reply With Quote
Best wishes IAIN
clbarclay
posted on 18/2/05 at 10:43 PM Reply With Quote
Going back to the qestion of what the advantage is, its obvious you half the cost of coil overs which start at aroud £300 for a set of 4
A set of 2 would only be £150
That Formula Renault, the suspension looks rock solid in effect it would be like using a solid (not spring steel) roll bar. precisly the oposite of what we are all worried about.
<<  1    2  >>
