flak monkey
posted on 21/2/05 at 05:55 PM |
Escort Rack Extensions
Can anyone tell me what length their track rod extensions are for wide track, escort racked cars...
I should be able to make myself some...so just need some measurements (length mainly), can someone help?
Sera
http://www.motosera.com
Stu16v
posted on 21/2/05 at 08:21 PM |
Sory to be pedantic, but it depends on how much wider the 'wide track' is....
flak monkey
posted on 21/2/05 at 08:23 PM |
Yeah sorry, I guess I should have made that clear....
I mean for the Sierra based cars that use an Escort rack...like the GTS.
Sera
posted on 21/2/05 at 08:59 PM |
Just buy a set it is too critical a component the quality of the thread cuting and grade of steel required mean making making a pair is real not
on. If you look at the standard rack you will see the thread on the rods is rolled not cut.
craig1410
posted on 21/2/05 at 09:27 PM |
GTS sell them for their own car I think and they don't cost much. Check the GTS website for details.
Personally, I'm building a McSorley 7+4" chassis and I got a pair of extensions from "907" on the forum here. I'm not
sure if he's still making them as I think he has been very busy lately building exhausts for everyone but the quality was excellent, in
particular the threads. I don't want to say what I paid for them as prices do change but lets just say they were a bargain!
Craig.
ps. Ask yourself what you'd do if they were to break?? The answer I came up with was, "Crash!!!"
posted on 21/2/05 at 09:28 PM |
me too (from paul), and as craig says, a lovely well made part.
flak monkey
posted on 21/2/05 at 09:43 PM |
OK i will buy a pair then. The GTS ones are £16 a pair.
I could fairly easily make myself a pair from EN16 bar on a lathe. TBH I dont see the problem with cutting the threads as long as it is done properly.
I know rolled threads are stronger, but is that extra strength needed here...?
I would think the threads are only rolled on the rack because it is quicker and more economical to do this on a commercial scale (look at all the
bolts you buy).
Im not trying to justify that its ok to make myself some, just trying to understand why it is really necessary to buy them....
Sera
posted on 21/2/05 at 09:50 PM |
for me, cos im a lazy bugger and couldnt make them anyway! maybe you could!
craig1410
posted on 21/2/05 at 09:58 PM |
Here's a picture of my extensions in place. Sorry I thought I had a close up of one. Drop a U2U to 907 (Paul Gooderham - nice guy!) and
I'm sure he'll be able to fix you up. I'm sure it will be a change from building exhausts... Make sure you tell him I said that,
he'll appreciate it!
Craig.
[Just saw the last two posts - Looks like you've decided on a course of action. 'nuff said]
[Edited on 21/2/2005 by craig1410]
niceperson709
posted on 21/2/05 at 10:44 PM |
Extending these is an issue I am going to have to tackle very soon but as I am building a plus 2' frame and due to my rack placement I think
that I will not need much more than one inch or so on each side my question is this would it be OK (from a strength point of view) to shorten the tie
rods slightly taking all but say 20 mm of the threaded end off and making the extention with a long male portion to allow adjustment . (hope this
makes sense)
altenatively I seem to remember from some where that cortina tie rods are longer than the escourt ones and that they have the same size ball end so
they could be exchanged for the Escourt ones to give extra length . If any one can confirm this It would be apreciated
best wishes
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
Stu16v
posted on 22/2/05 at 06:04 PM |
TBH I dont see the problem with cutting the threads as long as it is done properly. I know rolled threads are stronger, but is that extra strength
needed here...?
Good question. The threads in the TRE's themselves are cut...
posted on 22/2/05 at 06:19 PM |
needed here...?
They are internal the stress raiser and fatigue issue dosen't occur to anythng like the same extent, I am not saying the threads can't
be cut just the quality and finish of the thread has to be spot on .
posted on 22/2/05 at 06:27 PM |
quote: Originally posted by niceperson709
snip I seem to remember from some where that cortina tie rods are longer than the escourt ones and that they have the same size ball end so they
best wishes
Iain
70s Cortina,Garnada,Fiesta and Escort MK2 track rod ends are exactly the same part number. Sierra ones are longer, some Volvos use the same
thread as the Rover SD1 (P76?) but I don't know about the taper size
posted on 22/2/05 at 09:57 PM |
I seem to remember from some where that cortina tie rods are longer than the escourt ones and that they have the same size ball end so they could be
best wishes
Iain
Unfortunately not. I had the same idea and stripped down a Cortina rack only to find the track rods were pretty much exactly the same length.
niceperson709
posted on 22/2/05 at 10:39 PM |
Thanks for the prompt answer guys
best wishes
Iain
Best wishes IAIN
Stu16v
posted on 22/2/05 at 10:47 PM |
Purely of interest/learning: Why?
posted on 23/2/05 at 08:53 AM |
Track rods are a bit of a problem because they are a slender column in compresion and it will want to buckle. With buckling the outer surface is
subject to the most stress , and the weakest point on the outer surface is the sharp corner at the root of the thread.
This isn't a problem with the track rod end because te outer surface is a larger diameter.
Rolling the thread to a large alleviates the stress raiser and creates improved mechanical properties at the root of the tread.
Going back a few years I don't know if anybody on the list remembers the Africar project -- a CV2 based low technolgy cross country vehicle.
The developers found that to to enable the ground clearance to be raised they had to introduce a very slight bend in the track rods -- this
resulted in failures even in road use that no ammount modification and reinforcement was able to fix.
[Edited on 23/2/05 by britishtrident]
paulf
posted on 23/2/05 at 10:31 AM |
How about drilling and tapping the extension at each end and then screwing in a length of studding cut from a high tensile bolt or capscrew, to form
the external thread.It could be locked in with locktite and a thin locknut.
Paul.
needed here...?
Northy
posted on 23/2/05 at 06:21 PM |
Do you happen to know roughly how much longer? Are they the same taper as Cortina and Escort ones?
[Edited on 23/2/05 by Northy]
Graham
Stu16v
posted on 23/2/05 at 06:53 PM |
Ahh. I see, thanks for that. If only Whitworth threads were still in use...
I am guessing that you are picturing 'cut' threads overhanging, or protruding beyond the original TRE? I was picturing a male/female
extension that would screw into the original TRE fully, using the 'shoulder' of the extension to butt against the TRE. This way the
threads are only being used as threads IYSWIM, and not being put under tension/compression loadings (or at least, vastly reduced). Tracking adjustment
would be by the original track rod being screwed in/out of the extension.
The weak spot would be the transiton of cut thread to shoulder, but that can be overcome with careful design...
[Edited on 23/2/05 by Stu16v]
ChrisS
posted on 23/2/05 at 07:58 PM |
Craig1410
Just wondered what type of rose joint you used for your steering column support, as i am using 19mm tube to extend it, i havent manged to find a rose
joint with a 19mm eye.
Cheers.
[Edited on 23/2/05 by ChrisS]
craig1410
posted on 23/2/05 at 11:59 PM |
Chris,
It's not 19mm, it is 16mm solid bar and the rod-end is an M16 female joint. I got it from a company called BSL Ltd in Irvine, Ayrshire. I think
they were something like £16 each although I'm not certain.
I also got M16 bolts to suit the shank.
16mm solid bar seems to fit very snugly inside 19mm 16swg tube so I used the tube to join the bar where required.
I just used locktite to secure the steering shaft to the rod end inner bearing although it was already a tight mechanical fit.
HTH,
Craig.
