Author: Subject: Prop Shaft Flange and BEC prop
Avoneer
posted on 27/2/05 at 08:28 PM Reply With Quote
I have two English diffs, both with different prop flange sizes. The best one of the two for a BEC (3.77) has the smaller size flange and the other (3.89) the larger flange.
Is it easy to get a prop for my BEC with the smaller flange on the end?
Pat...
stevebubs
posted on 27/2/05 at 08:42 PM Reply With Quote
Pat,
as you'll most likely be getting the prop made to measure, it shouldn't matter which diff you use - just let them know the diameter / pcd and you should be fine
Stephen
Avoneer
posted on 27/2/05 at 10:12 PM Reply With Quote
Cheers Steve.
Didn't know if the manafacturers only made them with the large flange.
How's the car coming on?
Noticed the website is coming on!
Pat...
stevebubs
posted on 27/2/05 at 11:18 PM Reply With Quote
Originally posted by Avoneer
Cheers Steve.
Pat...
It *may* depend on where you're going but the posts I've seen indicate that so long as you tell them up front exactly what's at each end then they'll make it up to order.
Website comes on when it's too late to do anything noisy in the garage.
*Finally* managed to get the sump on (just spent 10minutes getting that horrible black Ford Silicon Sealant off my hands)
Fingers crossed it's oiltight!
