ady8077
posted on 28/2/05 at 09:08 PM |
108 pcd
Hi all
Apart from Ford, Peugot and Citroen, are their any others? I'm trying to find some larger brake disks
Adrian
GeoffT
posted on 28/2/05 at 09:16 PM |
According to the data I've got you can add Audi 80,90,100 and Saab 900 (88-92)
posted on 28/2/05 at 09:30 PM |
It's a fairly trivial operation to get disks re-drilled to a different PCD (as long as there is sufficient material to drill).
big_wasa
posted on 28/2/05 at 09:54 PM |
Brakes dont come much bigger than whats available to the ford cosworth range and they will have the correct pcd??
ady8077
posted on 28/2/05 at 10:13 PM |
Hi Mike
I hadn't thought of redrilling, Rover 800 disks are about the size i'm after, would it be best to elongate the original holes or drill new
ones inbetween?
Hi big_wasa
i'm hoping to fit the new willwood powerlite calipers
http://www.rallydesign.co.uk/catalog/product_info.php?products_id=10498&osCsid=6df7fdd54c6be64c531318983c5edb0a
They only fit disks up to 22mm thick, cossy disks are 24mm
Adrian
200mph
posted on 1/3/05 at 12:41 AM |
there are various sizes of disk available for the wilwood calliper, the largest thats less than 22mm thick is probably the 285x21, which needs at
least a 15" rim for clearance. Thats assuming its for a cortina hub.
If its for a different application, you can go up to 310x21.
The kits are listed in both Burton Power and Rally Design, so I assume they will sell the disks seperately if need be.
cheers
Mark
Rorty
posted on 1/3/05 at 03:52 AM |
quote: Originally posted by ady8077
Hi Mike
ones inbetween?
Adrian
Definitely drill new holes.
Cheers, Rorty.
gazza285
posted on 1/3/05 at 05:56 AM |
Use Focus disks, these are 258x22mm.
posted on 1/3/05 at 07:40 AM |
Rover 800 discs come in 2 sizes ---- and it isn't always obvious which models have the big discs most including many V6 and Turbo models use
the small disc.
The early 2.5 Honda V models and "Vitesse Turbo Sport" definitely used the big disc. The Centre spigot hole on th Rover is the same dia
as the Cortina/Escort fitting. They should have enough "meat" between the existing pcd holes to drill fresh holes.
Andybarbet
posted on 1/3/05 at 09:23 AM |
Try this link for wheel specs : http://jallaracing.morradi.com/boltsirkel.htm
Also, audi 80 is 108pcd cos im building my chassis on a set of steels from the wifes 80...
posted on 1/3/05 at 10:30 AM |
Some older Saabs are also 4.25" pcd the same as Ford
ady8077
posted on 1/3/05 at 11:03 AM |
Thanks for all the info
Its for Sierra hubs, Rally design only list a solid disk kit using the powerlite calipers
Adrian
