clbarclay
posted on 2/3/05 at 09:26 AM |
The book strikes again.
Currently using the 2nd edition book.
fig 4.35, page 64
The diagram states the distance between holes/trailing arm centre lines to be 5.75" or 146mm
fig 6.2, page 72
The diagram says that the distace between the trailing arm holes is 135mm - 25mm = 110mm
Correct me if I'm wrong but the trailing arms should be parallel, which means that there is a staggering 36mm difference between the 2.
Which measure ment is correct?
timf
posted on 2/3/05 at 11:07 AM |
147 is correct
search for a post from Mark Allanson
one on them has an anotated piccy
white130d
posted on 2/3/05 at 12:11 PM |
Me too
I think I too, noted the error and posted pictures several months ago...
David.
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
clbarclay
posted on 2/3/05 at 12:56 PM |
Thanks.
Mark Allanson
posted on 2/3/05 at 07:37 PM |
I fell into that trap and still have the holes to prove it
mattpilmoor
posted on 3/3/05 at 07:43 AM |
I did my brackets last weekend and noticed this. I built a jig to position the brackets and align the axle so that all would work as it should. First
time i drilled the jig to the book measurements I could see it was a MILE out! Re-drilled the jig and all's fine.
[Edited on 3/3/05 by mattpilmoor]
Measure twice - Cut once - Still f*!K it up!
clbarclay
posted on 3/3/05 at 09:10 AM |
I was lucky with this one and found out about the anomily before cutting and drilling the brakets.
