Author: Subject: Another broken wishbone ???
Jon Ison
posted on 2/3/05 at 04:06 PM Reply With Quote
Can opener/worms springs to mind.
http://www.blatchat.com/t.asp?Id=76495
[Edited on 2/3/05 by Jon Ison]
Ben_Copeland
posted on 2/3/05 at 04:12 PM Reply With Quote
Hmmmmmm snapped at 30mph moderate braking...... thats not good !!!!!!!!!!!
Ben
Locost Map on Google Maps
Enter Your Details Here
200mph
posted on 2/3/05 at 04:18 PM Reply With Quote
I guess its good motivation to check everything regularly. From what was said the corrosion may have been visible before it was driven.
not good though
Mark
marktigere1
posted on 2/3/05 at 04:37 PM Reply With Quote
Corrosion on a Cateringvan
If a bolt is stuck force it.
If it breaks, it needed replacing anyway!!!
(My Dad 1991)
posted on 2/3/05 at 05:10 PM Reply With Quote
i reckon the previous owner gave it a whack on the front wheel, set the ball rolling. This fella only had it two weeks. Plus it was parked up for some time before that, maybe long enough for the water to get in and get busy?
jollygreengiant
posted on 2/3/05 at 05:37 PM Reply With Quote
Q. ---- "Where did it fail?. "
A. ---- " California"
posted on 2/3/05 at 05:59 PM Reply With Quote
So - have you seen this happen before then Jon? Can you remember the outcome at all?
Jon Ison
posted on 2/3/05 at 06:17 PM Reply With Quote
i'm not gonna go there, just seems ironic that such a thing could happen and people suggest maybe its had a bit of a knock ?
posted on 2/3/05 at 06:56 PM Reply With Quote
theres two cans of worms on that thread - they nearly get onto the crush tube one!!!
jollygreengiant
posted on 2/3/05 at 07:06 PM Reply With Quote
Diagnosis at a distance is a dangerous thing, but I think that the pictures are quite telling.
Stress cracks. Any-time Any-place any-where. ( careful examination, IMHO, gives two. Primary and secondary.)
As you said John, a can of worms.
posted on 2/3/05 at 08:54 PM Reply With Quote
For me the download of the big picture stalled in the last few megs but from the small pics it looked like a brittle fracture --- a welding/material spec problem rather than a design issue.
[Edited on 2/3/05 by britishtrident]
jollygreengiant
posted on 2/3/05 at 09:46 PM Reply With Quote
Yep that looked about it. It looked like 1/2-3/4 of the tube had a 'polished surface and the rest had the texture of a brittle fracture. Where-as the bush tube looked like it fractured from excess stress starting at a minor corroded hairline crack( about 3 - 5mm long) IMHO.
First to fail was the rear tube and then the bush tube.
